Lost my haynes can you tell me what code 13 is.
I lost my haynes manual and need to know what code 13s is. Thanx your help will be greatly appreciated.
Re: Lost my haynes can you tell me what code 13 is. (ekhybrd)
I searched and found this.....
https://honda-tech.com/zerothread?id=758791
Re: (ekhybrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">buzump</TD></TR></TABLE>
why?
you got your answer, its the barometric pressure sensor.
Rob
why?
Rob
Re: Lost my haynes can you tell me what code 13 is. (hondatim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim »</TD></TR><TR><TD CLASS="quote">just curious, are you running an AFC by any chance?</TD></TR></TABLE>
yes why? And another thing it only threw this code once....ive driven the cars manny times after that and it has not thrown a cel at all after that one time
it's just that I've seem AFC's cause issues with ECU due to MAP sensor signal being modified. The ECU sees this modified MAP signal and sometimes thinks that Baro sensor is faulty and will set light. I wasn't sure if you had experienced this before, it's just something that I have ran into before.
just an afterthought...
again, I was just curious
Thanks for the info
this is the first time my ecu has thrown that code.....and it was only that one time It hasnt thrown a cel at all since then
drumminforev
25
11-11-2006 09:19 PM
