EMS help - Experts please Read! Coil per plug info
Sorry for posting again guys. Please don't delete...I really need this answered.
Thanks.
I want to run one coil per cylinder. On my EMS I have to run a crank sensor, but to run 4 coils I also need a cam sensor.
I'm going to buy Electromotive's crank wheel and sensor but I can't find anyone that makes a cam wheel and sensor.
Do you guys know of any company that makes one?
If not, can I use the stock distributor and gut it out and only keep one of the sensors in there as a cam sensor? My EMS allows me to change the amount of teeth to look for so I was thinking I might be able to do this. Then I could just make an aluminum cover for the distributor instead of using a cap.
Any help is greatly appreciated guys....thanks in advance!
Thanks.
I have just heard of people using the stock dizzy for this.. I remember seeing somewhere that someone was making a new dizzy housing that looked cool for this purpose..
Are you sure you can do the DFI setup with the honda ems unit.. I have heard that there is only 3 coil output so the best you can do it wastefire setup..
wantboost
May 2, 2014 11:26 AM
