ticking sound when turning
Old Nov 28, 2001 | 09:20 AM
4doorH22's Avatar
Default ticking sound when turning
Hi. When I make a right turn at slow, parking lot speeds, I hear a ticking sound coming from my driver's side front wheel. Initially I thought it might be the wheel bearing, but now I've noticed it only ticks when in gear. So if I coast through a right turn with the clutch in or in neutral, there is no sound, but in gear the driver's front wheel goes tick, tick, tick...
Does anyone have any idea what this could be? Something with the differential? There are no other symptoms, just this ticking sound.
Thanks
Old Nov 28, 2001 | 09:24 AM
DR. ON POINT's Avatar
Banned
Default Re: ticking sound when turning (4doorH22)
axle
Old Nov 28, 2001 | 09:26 AM
ForcedAccord's Avatar
Texas B*tch!
Lack of fluids? Power steering, tranny, I don't know it could be multiple things. When did it start? Worse comes to worse, it could be a bomb
Old Nov 28, 2001 | 09:33 AM
RyanR's Avatar
You need a new axle, your outer CV joint is worn.
Old Nov 28, 2001 | 09:36 AM
SOHCArchangel's Avatar
Default Re: ticking sound when turning (97TypeR_9)
ccan you get it 2nd day air man,....its gonna be a looong weekend again
Old Nov 28, 2001 | 09:47 AM
Texas B*tch!
Default Re: ticking sound when turning (SOHCkordVTEC)
how much does an axle cost?
Old Nov 28, 2001 | 09:50 AM
zeoth's Avatar
Hold on... before you go and change your axel, check first to see if the CV boot broke and lost all it's lube. I had this problem and the fix was simple... tighten the bolt that holds the axel in place and lube it. (take off your rims and you should see a bolt in the center of the rotor. A new axel and installation shouldn't cost you more than $250 at a shop... or you an do it yourself.
Old Nov 28, 2001 | 09:51 AM
4doorH22's Avatar
Default Re: ticking sound when turning (ForcedAccord)
Thanks y'all.
Rebuilt axel should be 100~125.
Old Nov 28, 2001 | 09:53 AM
Texas B*tch!
Oh ok, sounds more serious than it really is I guess. Still what a pain, how often do axles give out?
Old Nov 28, 2001 | 10:27 AM
Banned
wtf are u gus talking about..go to pep boys with ur old axle and give tha to them and 80 bucks and u got a axle wtha alifetime warranty...its realy esy to put a axle in, half hour tops....rebuilt axle 100 bucks is bull ****...u have a preludemoo in ur accord, u should know stuff like this
Old Nov 28, 2001 | 04:27 PM
fsarfino's Avatar
Default Re: ticking sound when turning (On Point)
yeah I would go the pep boys route also that way if ya ever snap it you can get a new one for free.
Old Nov 28, 2001 | 04:52 PM
fixhondas's Avatar
Default Re: ticking sound when turning (dohcvtec16)
Yeah- go to pepboys and buy an $80 piece of absolute garbage!! I tried FOUR of their "rebuilt" junk axles and they all knocked within a week. I got my money back. This was one step in my education on how aftermarket parts are GARBAGE. Don't take my word for it, try it for yourself. Maybe you could have pepboyZ install it for you and break your differential side gears in the process. The shift quality would be excellent if you are unfortunate enough that they use 90 weight gear oil in your tranny!! That place is a Honda's worst nightmare. I wouldn't go there to buy washer fluid.
[Modified by fixhondas, 8:53 PM 11/28/2001]
Old Nov 28, 2001 | 06:53 PM
Banned
Default Re: ticking sound when turning (fixhondas)
works fine for my friends
Old Nov 29, 2001 | 05:58 PM
BreakStuff's Avatar
New User
I'll back fixhondas here and completely agree that a majority of aftermarket parts are garbage... or to put it another way, A good chunk of my weekly paycheck comes from people who attempt to save a few bucks buying **** parts...
DC2_fresno_CA
Mar 29, 2010 03:00 PM
phoshyzzle
Apr 12, 2008 01:13 PM
rhetorical
Nov 29, 2004 11:45 PM
inty2511
Jun 9, 2004 09:56 PM
Accord_Kid
Aug 25, 2003 10:45 PM
