help! Im stranded!
Old Aug 1, 2004 | 03:20 PM
3.3.3's Avatar
Default help! Im stranded!
Picky Bitch Started Driving Just Fine
Modified by 3 3 3 at 11:28 AM 8/4/2004
Old Aug 1, 2004 | 03:24 PM
Deemeetree's Avatar
Electrician
Check the condition of your shifter bushings. How long has it been since you flushed your tranny and topped it off with fresh fluid?
Old Aug 1, 2004 | 03:27 PM
3.3.3's Avatar
Default Re: (Dimi)
the fluid was replaced exactly 3100 miles ago....
Old Aug 1, 2004 | 03:32 PM
dampachi's Avatar
Default Re: (3 3 3)
yeah sounds dumb but check your shifter bushings... maybe somethings there causing extreme friction
Old Aug 1, 2004 | 03:34 PM
zman's Avatar
Default Re: (3 3 3)
start the car in 1st and drive it onto the trailer. I had the same problem and all i did was flush the clutch fluid and then it was fine. Try this before you put it on the trailer...its easy to do don't even need to jack the car up cause the bleeder screw/valve is on slave cylander on the front of the tranny. Its the same as bleeding the brakes. Just get the wife to grab some brake fluid before she picks u up.
Old Aug 1, 2004 | 03:35 PM
3.3.3's Avatar
Default Re: (dampachi)
ill check it out....oh yeah, there is a really anoying squeeking sound when you press down on the clutch pedal.
Old Aug 1, 2004 | 03:36 PM
3.3.3's Avatar
Default Re: (zman)
thanks....i gotta try to catch her before she gets here. i dont think there are auto supply stores in this snazzy neighborhood.
Old Aug 2, 2004 | 07:49 AM
3.3.3's Avatar
Default Re: help! Im stranded! (3 3 3)
***update***
the car started driving normal....weird. i was gonna pull onto the trailer, but then it starded driving fine.
civic99585
Jan 27, 2009 11:14 PM
prionailurus
13
Oct 23, 2008 08:09 AM
fanta!
12
Dec 30, 2005 06:59 AM
tegasaurus
Jan 21, 2003 08:31 PM
Nate B
Jun 18, 2002 01:50 PM
