help! Im stranded!
Picky Bitch Started Driving Just Fine
Modified by 3 3 3 at 11:28 AM 8/4/2004 |
Check the condition of your shifter bushings. How long has it been since you flushed your tranny and topped it off with fresh fluid?
Re: (Dimi)
the fluid was replaced exactly 3100 miles ago.... https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (3 3 3)
yeah sounds dumb but check your shifter bushings... maybe somethings there causing extreme friction
Re: (3 3 3)
start the car in 1st and drive it onto the trailer. I had the same problem and all i did was flush the clutch fluid and then it was fine. Try this before you put it on the trailer...its easy to do don't even need to jack the car up cause the bleeder screw/valve is on slave cylander on the front of the tranny. Its the same as bleeding the brakes. Just get the wife to grab some brake fluid before she picks u up.
Re: (dampachi)
ill check it out....oh yeah, there is a really anoying squeeking sound when you press down on the clutch pedal.
Re: (zman)
thanks....i gotta try to catch her before she gets here. i dont think there are auto supply stores in this snazzy neighborhood. https://honda-tech.com/forums/images...s/emthdown.gif
Re: help! Im stranded! (3 3 3)
***update***
the car started driving normal....weird. i was gonna pull onto the trailer, but then it starded driving fine. http://images.honda-tech.com/set1//smile/emcrook.gif |
