how to check tranny fluid levels?
Re: (fanta!)
no, that would be more of a syncro problem. its its not major yet, go ahead and flush the old tranny fluid out and add about 1.5 quarts of Honda Tranny Fluid and a bottle of Lucas transmission fluid. It works for me for another 8 months or so.
Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">I don't think you can check your tranny fluid level except by changing it :shurgs:</TD></TR></TABLE>
you can - undo transmission "fill" bolt , and simply put ur finger inside the hole and feel for the "level" - it should be just at the base of the fill hole. If below just top up until it slowly leaks out of the hole.
cute little bastard
Re: (bennjamin@ozhonda.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennjamin@ozhonda.com »</TD></TR><TR><TD CLASS="quote">
you can - undo transmission "fill" bolt , and simply put ur finger inside the hole and feel for the "level" - it should be just at the base of the fill hole. If below just top up until it slowly leaks out of the hole. </TD></TR></TABLE>
d0h!
Can it be done through the VSS hole too?
d0h!
Re: (nocturnaldragon)
yup the proper way is as i said above - check your manual or online manuals and they mostly tell the same tale. (use a finger via the fill hole)
The VSS is the best way to fill methinks , just be careful retightening those 2 small 8 or 10mm bolts holding the VSS inplace *snap easy*
