'93 civic no spark
Old Jul 31, 2004 | 06:19 PM
mommy4max's Avatar
Default '93 civic no spark
I have been reading through similar problems and I am stumped. We have replaced the ICU, the distributor doesn't have a mark on it, put in a new coil, new plugs. I have read about the main relay, but we can hear the fuel pump come on and we don't really have any other symptoms of a main relay failure. Any ideas? This all started a while back when the car's RPM gauge would jump up and down and sometimes completely stall. This was an intermittent problem and then the other day the car just died and hasn't had a spark since.
Thanks
Old Jul 31, 2004 | 06:57 PM
t25hatch's Avatar
Default Re: '93 civic no spark (mommy4max)
could be ecu
Old Jul 31, 2004 | 06:59 PM
Dancing is Forbidden's Avatar
Default Re: '93 civic no spark (t25hatch)
well if you say the fuel pump isn't priming then it is the main relay. But I don't see why that would happen with your swap. When I put a DX head on my b8 I didnt have any problems. GL figuring it out. Check for fuel and spark, that should eliminate some problems.
Old Jul 31, 2004 | 09:17 PM
roydogg's Avatar
try swapping out a whole new dizzy?
Old Jul 31, 2004 | 09:41 PM
mommy4max's Avatar
Default Re: '93 civic no spark (roydogg)
well, apparently we have spark now, although somewhat weak. Go figure. Thanks for all your suggestions. I'm sorry, I don't know what the "dizzy" is. Open to more suggestions.
Thanks
Old Jul 31, 2004 | 09:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mommy4max &raquo;</TD></TR><TR><TD CLASS="quote">well, apparently we have spark now, although somewhat weak. Go figure. Thanks for all your suggestions. I'm sorry, I don't know what the "dizzy" is. Open to more suggestions.
Thanks </TD></TR></TABLE>Dizzy is short for distributor
Old Jul 31, 2004 | 10:45 PM
mommy4max's Avatar
Default Re: '93 civic no spark (lsvt3c)
Had a hunch it was probably that but didn't want to assume anything at this point. Thanks.
Old Jul 31, 2004 | 10:47 PM
Mommy
Stacy
Hmmm.
Whispers to everyone but you
"leghumpers, shes a lady, you know you don't need pics, just hump away"
philztheone
Nov 5, 2014 10:28 AM
-Hooper-
Jun 8, 2009 08:42 AM
crexsi
May 8, 2009 06:44 PM
dan617
10
Jan 31, 2009 02:10 PM
