my motor is TOAST
Old Jul 31, 2004 | 03:20 PM
Poopie's Avatar
Default my motor is TOAST
On the way home from work two days ago I noticed a whirring type sound. I thought it was a belt or something and it lacked power, not like I had much to start. Today I changed my oil since its been about 3000 mile since my last. When I was draining the oil only about 1.5 quarts came out. HOLY HELL. Have I been driving around with only 1.5 quarts of oil? The engine never over-heated. Can I save this engine? There is 86k miles on the engine. Its just a dy16y7 and I don't have much cash to spend on a new motor or a rebuild. What could I have destroyed and how much would it cost to fix?
Old Jul 31, 2004 | 03:22 PM
Deemeetree's Avatar
Electrician
Did your oil light come on? Did your CEL come on? Put in the correct amount of fluid and drive it around. Put in a new filter. I'm thinking you didn't do much damage.
Old Jul 31, 2004 | 04:24 PM
SprayinCX's Avatar
Default Re: (Dimi)
slap some new acl bearings in it. be sure to hone it. then there you go.
bearings =100
hone job = depends on the machine shop
labor = do it yourself
Old Jul 31, 2004 | 04:37 PM
AzCivic1.6's Avatar
Default Re: (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">slap some new acl bearings in it. be sure to hone it. then there you go.
bearings =100
labor = do it yourself</TD></TR></TABLE>
yeah its that easy
Old Jul 31, 2004 | 07:17 PM
Poopie's Avatar
Default Re: (AzCivic1.6)
Its not as bas as I thought after I put some mobile 1 in it and drove it around. There is definatly a loss of power though. I'm gonna see if I can find someone with the same motor and same milage to compare compression. Its good enough to safely get around so when I get some cash I'll do a swap and get rid of my auto tranny.
LS97Civic
Apr 24, 2012 07:48 AM
campbell81
Jul 20, 2008 06:59 AM
jarven093
25
Apr 26, 2007 01:12 PM
kihun_cha
13
Oct 6, 2004 11:49 AM
slow99si
17
Jan 6, 2004 05:20 AM
