Did not cut bump stops.....
Old Jul 30, 2004 | 02:01 PM
clutch33's Avatar
Default Did not cut bump stops.....
I lowered my car a few months back and never cut the bump stops. What do thet do and what will happen if I don't cut um???
Old Jul 30, 2004 | 02:09 PM
deviant1's Avatar
Default Re: Did not cut bump stops..... (clutch33)
they prevent your strut from bumping up against your shock tower, or bottoming out. if you dont cut them, depending on how low you are, you will be riding on your bump stops and this creates one hell of a nasty ride quality. it basically takes your struts out of the equation.
Old Jul 30, 2004 | 02:41 PM
ej1 pilot's Avatar
Default Re: Did not cut bump stops..... (HondaHick)
i took mine out
Old Jul 30, 2004 | 02:51 PM
Draggin99Si's Avatar
It also depends on your springs. When I was running H&R Sports, the instructions specifically stated not to cut the bumpstops. So check with your spring manufacturer first.
Old Jul 31, 2004 | 07:23 AM
clutch33's Avatar
I got s-tein springs, lowered about 1.5 to 1.75". Should I cut it. It is a harsh ride.
Old Jul 31, 2004 | 07:38 AM
mildly.interesting's Avatar
cut them in half....
Old Jul 31, 2004 | 09:09 AM
Andres-eh2's Avatar
i know that eibach sportlines say how much to cut it
Old Jul 31, 2004 | 09:19 AM
turbotime's Avatar
I got ground controls and they said cut the last notch of the bumpstop off, i still hit it tho. I am gonna cut one more notch off and if that dont work im gonna extend the shock travel..
MrOsvaldo221
Suspension & Brakes
Sep 2, 2013 08:54 AM
bopbop93030
Oct 28, 2008 07:02 PM
vipersr10
Feb 5, 2006 08:17 PM
hondaracing1
Mar 28, 2005 09:32 AM
91ReXSI
Jan 6, 2002 03:43 PM
