A bit off topic: A 240sx brake question?
Guest
Posts: n/a
Well as you guys know I bought a 240sx for about 900 Bucks and I have sort of a little problem. Sometimes the brakes feel like they get stuck . I got some new pads for em and nothing. What usually causes this problem.
most calipers work the same way. there's the main cylinder that applies pressure to the inside pad, and two sliders that the outside pads will slide on to apply pressure to the rotor. Sometimes those boots on the sliders get messed up and the sliders grease will dry up and won't return to the "open" status as easily. Check those sliders, clean them up and apply the correct high temp break grease. that should solve your problem. Make sure your boots are secure to avoid the issue in the future.
Guest
Posts: n/a
I hope I explained myself right and thanks for your help. The reason I think its my brakes its because the car slows down like you are very easily tapping the brake it wont roll for a long time with you pressing the gas it will slow down . Thanks for you help and ill try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks »</TD></TR><TR><TD CLASS="quote">I hope I explained myself right and thanks for your help. The reason I think its my brakes its because the car slows down like you are very easily tapping the brake it wont roll for a long time with you pressing the gas it will slow down . Thanks for you help and ill try that.</TD></TR></TABLE>
hope it works
hope it works
Sliders
The grease is about 3 bucks from auto zone. And I do believe that you can get boot kits from them as well for not much.
An easy way to check is to remove tha pads and just try to push and pull and push the caliper. It should move with very little effort.
Nishant
Jun 12, 2006 09:39 AM
sugarloafpkwy
14
Dec 4, 2005 07:31 PM
CXHatchback
21
Mar 20, 2003 07:13 AM
