Clutch/tranny problem
Old Jul 30, 2004 | 09:44 AM
blueteg007's Avatar
Default Clutch/tranny problem
So I just installed a new clutch (ACT extreme pp, organic disc correct codesfor my integra) and new bearings on the tranny main shaft, and I've done it 3 times by now!! I can switch through all the gears with the car off, but when I turn it on I'm locked out of everything except reverse which grinds to much to make we wanna try to get it in gear. I took it to a shop and they think everything looks fine. Hydraulic system looks good, clutch pedal feels good and stiff, the clutch fork looks like it has travel. Any ideas what the problem might be?
Old Jul 30, 2004 | 11:49 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Clutch/tranny problem (blueteg007)
You sure you have all the air out of the lines?
Does it grind if you TRY to put it in gear with the car on? Put more pressure on the stick and see what happens. Don't actually put it in, but see if there's a grinding.
Or does it physically not go in, like you're hitting a wall?
Stupid question: Are you sure the linkages are installed correctly? Lined up and whatnot?
Old Jul 30, 2004 | 06:10 PM
daddycivic's Avatar
Did you torque in the presser plate correctly?
mawkiemarc
Aug 1, 2005 08:41 PM
toEknEEg
Aug 25, 2004 05:19 AM
RJL
Nov 28, 2003 11:25 AM
mr_mbuna
Oct 5, 2002 08:59 PM
phatintegra
Mar 21, 2002 08:46 AM
