Were do I put the oil pressure sensor for a oil pressure gauge
Old Jul 29, 2004 | 12:31 AM
GDM93Si's Avatar
Default Were do I put the oil pressure sensor for a oil pressure gauge
CAn some one help me out were can i put (or were dose it go). the oil pressure sensor for a oil pressure gauge electronical.
Old Jul 29, 2004 | 05:40 AM
speedymon's Avatar
Default Re: Were do I put the oil pressure sensor for a oil pressure gauge (JDM91DA)
Replace or "T" of the stock oil pressure sender on the back of the block.
Old Jul 29, 2004 | 06:53 AM
GDM93Si's Avatar
Were is it by. in the back of the block. If u can show me a pic it will be great thx...
Old Jul 29, 2004 | 06:54 AM
tnord's Avatar
Default Re: Were do I put the oil pressure sensor for a oil pressure gauge (speedymon)
if you're getting an electrical guage, you should mount the sender remotely on the firewall, fender, or anywhere else that isn't prone to vibration. aftermarket senders are usually larger than factory, and don't stand up to vibration as well because of it. you should also soft mount the sender wherever you end up putting it.
Old Jul 29, 2004 | 07:34 AM
IN VTEC's Avatar
This is my old line before I sold it and removed my old gauges. I'll fabricate a new one when I get the new gauges that's closer to the exact length. For this one, I just used the entire 3ft section of Aeroquip -3AN TFE hose and looped it.
This is the fitting that threads into the block where the stock sending unit goes. It uses a 1/8" BSPT (Male) to 1/8" NPT (Female) adapter -- 1/8" NPT (M) to -3AN flare aluminum adapter.
It's roughly $50 to $60 to buy the parts and put together the line yourself.
Old Jul 29, 2004 | 07:41 AM
tnord's Avatar
Default Re: Were do I put the oil pressure sensor for a oil pressure gauge (IN VTEC)
i bought basically the same thing (minus the T fitting) from autometer for about $40.
Old Jul 29, 2004 | 08:30 AM
IN VTEC's Avatar
Default Re: Were do I put the oil pressure sensor for a oil pressure gauge (tnord)
That Aeroquip aluminum tee is $11 or $12. That's reason enough for most people to not use it when a brass tee for $2 does the same thing...it's just a little heavier and uglier.
Old Jul 29, 2004 | 08:40 AM
tnord's Avatar
sounds about right.
Old Jul 29, 2004 | 01:53 PM
Boofster's Avatar
That looks like a lot of weight to hang from the block. I suggest an oil sandwitch.
Old Aug 24, 2004 | 11:54 AM
Will_H's Avatar
will a NPT thread screw into the back of the block? or does it have to be BSPT?
Old Aug 24, 2004 | 08:56 PM
IN VTEC's Avatar
Default Re: Were do I put the oil pressure sensor for a oil pressure gauge (WillisGS)
I find that 1/8" NPT doesn't like to go into 1/8" BSPT, but vice versa seems to work alright.
Old Aug 25, 2004 | 10:22 AM
Will_H's Avatar
Humm well last night i put the 1/8" NPT in the back of the block and it screwed in just fine and has no leaks... so i guess i got lucky.
OGMatt
Aug 15, 2011 01:11 PM
velisma
Jan 30, 2010 08:24 PM
2khb
Mar 10, 2005 06:52 PM
turbotime
Nov 29, 2003 04:58 PM
carl_aka_carlos
Jul 16, 2002 06:49 PM
