14 sec n/a d16z6, possible???
Old Jul 28, 2004 | 07:04 PM
Mr.Death's Avatar
Default 14 sec n/a d16z6, possible???
My plan is to get into the 14's with a n/a d series motor. So far I have a lightened flywheel, daikin clutch, 2 1/2 cat back exaust, dc sport header, cai. I under stand you can raise compression by using a d16y8 metal head gasket. Any other tricks for my quest for 14 secs?? Oh yeah, I have a 90 crx si. Thanks..
Old Jul 28, 2004 | 07:12 PM
goforbroke's Avatar
MEAT PATTY
Default Re: 14 sec n/a d16z6, possible??? (Mr.Death)
Their are a few guys on here who have 14's d16z6, I remember the one guy named bserieskllr, something like that.
1.weight reduction
2.skunk2 or edelbrock manifold
3.driving skills
That should put pretty close to high 14's. I'm not sure how much money you want to spend though. Because their are other things you could do, such as VAFC,ect....
Old Jul 28, 2004 | 07:17 PM
Mr.Death's Avatar
Default Re: 14 sec n/a d16z6, possible??? (goforbroke)
I plan on building the motor over time. First thing I'm gonna look at doing is chipping my ecu followed by a new cam. Maybe port and polish would be a good idea before installing it.
Old Jul 28, 2004 | 07:18 PM
Redline130's Avatar
Don't over look things like suspension and traction. You will need to be able to utilize whatever power you have and get it to the ground. A good suspension set-up with either some drag radials or slicks can help you achieve this. Also, if you can, get your car tuned on a dyno. You can not only fine tune you car, but you can also use the graphs to see where your power is, and thus help determine shift points. Good luck on your quest.
Old Jul 28, 2004 | 07:29 PM
deftones0817's Avatar
Default Re: 14 sec n/a d16z6, possible??? (Redline130)
i ran 14.8 with a stock d16a6 in a 1989 hf crx. This was on slicks. So if i can do that with a stock one. You should be able to do that with a little more hp. Good luck.
DEF
Old Jul 28, 2004 | 08:07 PM
goforbroke's Avatar
MEAT PATTY
How the hell did I forget to mention a "cam"
http://www.exospeed.com has all types of cams to choose from.
Old Jul 29, 2004 | 11:17 AM
SmobbinSi's Avatar
Default Re: 14 sec n/a d16z6, possible??? (deftones0817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">i ran 14.8 with a stock d16a6 in a 1989 hf crx. This was on slicks. So if i can do that with a stock one. You should be able to do that with a little more hp. Good luck.
DEF</TD></TR></TABLE>
I totally agree with DEF- I did it with my 89 CRX Si (d16a6), but with street tires.
Old Jul 29, 2004 | 11:19 AM
JOEY F.'s Avatar
Default Re: 14 sec n/a d16z6, possible??? (SmobbinSi)
check out my sig dude
Old Jul 29, 2004 | 12:20 PM
sm00thk0zz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Don't over look things like suspension and traction.</TD></TR></TABLE>
Jim Fab traction bars, adjustable shocks
Old Jul 29, 2004 | 01:00 PM
phatrick2332's Avatar
with just bolting in a z6, with the proper tuning to actually make it run correctly you should be damn close to 14s, with i/h/e, you SHOULD be mid to high 14's. That is, if you kno how to drive..
My buddy in an 88 hf, swapped to z6 with a borrowed zdyne, ran a 14.7 with stock manifold, and exhaust.
ZombieKing
Feb 17, 2013 10:37 AM
roberts
21
May 1, 2006 12:22 PM
DRKSol
Jun 4, 2003 10:54 AM
Hybrid
Feb 26, 2002 12:03 PM
asnx6pac
25
Dec 9, 2001 06:44 PM
