CODE 5 [SEARCHED]
Old Jul 28, 2004 | 12:05 PM
909rex's Avatar
Default CODE 5 [SEARCHED]
ok i searched forever abotu this code and it seems no one else runs into this problem... its code 5 with a jdm ecu running a b18c1. Its "MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping ". How would i go about fixing this? Ive tried different MAP sensors but same thing. Any help would be appriciated.
Old Jul 28, 2004 | 12:19 PM
909rex's Avatar
Default Re: CODE 5 [SEARCHED] (b18CrxSi91)
no i dont... should i get one? would that fix the problem?
Modified by 909rex at 1:52 PM 7/28/2004
Old Jul 28, 2004 | 01:50 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: CODE 5 [SEARCHED] (909rex)
a code 5 is a vacume conection to map. i'd check you TB conection.
Old Jul 28, 2004 | 02:38 PM
RCautoworks's Avatar
Default Re: CODE 5 [SEARCHED] (JC18)
Code 5 - MAP Sensor
Usually means there is something wrong with the hose.
When the MAP voltage is too high (indicating vacuum is lower then normal) the problem is rarely a faulty sensor, but in fact a problem with the engine itself
* incorrect cam timming
* incorrect iginition timming
* restricted exhaust
* excessively worn engine or leacking valves
Old Jul 28, 2004 | 02:50 PM
909rex's Avatar
Default Re: CODE 5 [SEARCHED] (90blackcrx)
cool that helped out alot. but i got the code before even turning on the car... and the timing was TDC... by the way it has skunk2 IM with a b16 TB.. where should the vacuum line by at...
Old Jul 28, 2004 | 05:50 PM
909rex's Avatar
ok turned it on finally... now i was looking at the map sensor and the jackass who had the car before me just twisted and taped the the 3 wires together... now should they be soldered?
eggie75
Apr 7, 2008 01:40 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
Intercooled JRSC
Oct 23, 2004 08:08 PM
Achenar
Oct 2, 2004 01:45 PM
platinum00
Jul 24, 2003 08:02 AM
