No spark with MSD ignition, just started after like 5 months of working
I know this is a long explanation of my problem, but I just want to make sure I get the whole story straight so its easier for people to help me. OK here I go - I have had an MSD SCI ignition with an Accel coil and the MSD distributor cap with the external coil connection on my B18B1 since I put my turbo on like 5 months ago. It has worked great the whole time. Just 3 days ago I started having problems starting my car. I went to start it the first time and it tried to start but it sounded like it wansnt getting a spark. I put in new spark plugs (NGK BCPR7ES-11, just like the old ones) and it started up fine later that day. I drove it for 10 minutes to the bank and I went inside for like 5 minutes and when I came out it didnt start, and sounded exactly like it did before. I messed with the plug wires and connections for a little while and nothing helped. I left it there for like 5 hours and came back and it started up fine and I drove it back home. I started it later that night to check on it and it worked fine.
The next day I drove it to my friends house and it worked fine the whole time starting and on the way there. When I left I floored it and peeled out through 1st gear and when I shifted to 2nd and floored it again it cut off and wouldnt start again. I thought it would start again later like before but it didnt. I checked for spark from the plug wires and coil but there was nothing. I got an MSD Blaster 2 coil and put it on the next day, it didnt start right away but it started with the new coil after a minute. I drove it for about 10 minutes and it was running fine, and then I let it idle for like 5 minutes while I was at the car wash, but after I left there it wasnt idling right so I knew something was wrong, after I shut it off that time it hasnt started up at all since then. Is there a way I can check my distributor to see if it is the problem? I am going to check my MSD box tomorrow. Has anyone ever had any problems like this? Could it be my ECU messing up by any chance?
Thanks for any help
Thanks for any help
95blackEG
Dec 24, 2008 07:59 PM
