who is a good shop to rbuild heads
I have a B20A5 that I'm putting a turbo kit on. I'm buying the parts (rods ,rings and pistions) and having the bottom end rebuilt local. I want to have a shop exparinced with honda heads rebuild the heads. So my first quistion , The guy that built the kitsugested lowering the comprestion to 8.5-1 , and running the boost at about 10-12 psi. This car is going to be a summer driver , and wll see traffic , dose this sound like a good plan or can I lower it more and up the boost.
My second Question is who do you recomend to rebuild and mod the head. I bough some bullfrog cams befor I commeted on te turbo kit , I thought about working with them , reather then out right returning the cams ,what do you think.
You will want to keep the compression to around 9:1. Any lower than that is kinda silly. Will be too sluggish on the bottom end with 8.5:1 compression. I think that you should get your dinero back on those bull frog cams. You may want to check out portflow or JG for head work.
Ti3d in
Jul 11, 2004 02:45 PM
