B18C1 in CRX w/ Hydro ITR tranny
OK guys, I have done a couple of searches, and ended up kinda confused...
Here's my situation. Right now, I have a 97 Civic EX w/ a "Poor man's Type R" (B18C1 block, JDM ITR crank & rods, JDM CTR OS pistons, B16A head w/ CTR cams, ITR & Portflow valvesprings, Skunk2 titanium retainers & Skunk2 IM w/ bolt ons, running OBD1; P30 ECU) mated to a '00 ITR tranny.
I plan on selling the Civic and swapping that setup into my newly acquired '90 CRX HF. I already invested in the OBD0-OBD1 conversion harness. I plan on buying the HASport mount kit for hydro B-Series & HASport shift linkage for B-Series.
Now, I just wanted to make sure that I can continue to use the same axles that are on the civic in the CRX. If not, what axles do I need?
Also, will I be able to keep the same header? (DC SS JDM 4-1)
Any tips or advice to make this project run a little more smoother is really appreciated. TIA
-Vic
-Vic
I believe trackwidth is not the problem , the HF knuckles might, in that case you need different outer joints. I would recommend civic sedan 88-91 EX knuckles with the factory 260mm discs (same knuckle as the EE8/EE9/EF8/EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REX VT »</TD></TR><TR><TD CLASS="quote">I believe trackwidth is not the problem , the HF knuckles might, in that case you need different outer joints. I would recommend civic sedan 88-91 EX knuckles with the factory 260mm discs (same knuckle as the EE8/EE9/EF8/EF9)</TD></TR></TABLE>
which axles were you using in the 97 civic?
also, get knuckles from a 90-91 Civic EX Sedan (88-89 didnt have EX as far as I know)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
also, get knuckles from a 90-91 Civic EX Sedan (88-89 didnt have EX as far as I know)</TD></TR></TABLE>
I am using 96 integra gsr axles
Thanks for the advice guys, keep it coming
well you already have them so i'd give it a shot? lol..
I know most people go w/ 90-93 teg axles when doing b16 swaps...i hate figuring out which axles to use, always something different.
call hasport?
call hasport?
I hear that the gsr axles/int shafts work, I am personally running 90-91 teg axles and int shafts.
You will need 90-91 ex knuckles, or si/dx knuckles. The hf knuckle is too small.
Your header should work. I am running a dc 99-00 4-2-1 civic si header with no problems.
Ryan
Ryan
The only issue with the 4-1 header will be the ground clearance. The pipes will be closer to the ground than your typical 4-2-1 header.
The 96 gsr axles should work. At least I've been told they will work. I'll be installing mine today to find out for sure whats up.
I've been told you need to change the drivers side transmission seal to a 90-93 teg one for them to work right. (I could have something mixed up, so someone clarify for me if i'm wrong).
The only problem I see with the header is possible clearance issues w/ the crossmember.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">The 96 gsr axles should work. At least I've been told they will work. I'll be installing mine today to find out for sure whats up.
The only problem I see with the header is possible clearance issues w/ the crossmember. </TD></TR></TABLE>
no need to change the seal with gsr axles, thats only with a 90-91 teg int shaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">
no need to change the seal with gsr axles, thats only with a 90-91 teg int shaft</TD></TR></TABLE>
What if you have a 90-93 tranny and 94+ axles? Do you need to change the seal to a 90-93 one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel »</TD></TR><TR><TD CLASS="quote">You have to Cut the Cross member to fit toes 4to1 header
And cut the hood wher the cam gear are at it hit's
You can ueas GSR axels and haf shaft it works
JDM 89 to 91 B16A Sir1 part's work geart Too
OBD-0</TD></TR></TABLE>
Ok you will have to cut the front crossmember for the 4-1, I had that **** and it was a pain to get it to fit with the stock CM. I don't recommend it, it's way too low.
Don't have to cut the hood man, who the hell told you that?? ------Mis-information here-------
You can use what ever axles you had, but your HF knuckles(hole for axles are too small) will not accept the axles so you have to change the knuckles to another model. Best and easiest is to get the 90-91 teg knuckles for the 10.2" brakes but the offset is a little different(slightly forward or back can't remember).
that is why everyone else is recommending you to get the 90-91 EX knuckles, same 10.2" brakes and they have the right offset. It's just harder to get.
This is all from my experience built on my CRX
OBD-0</TD></TR></TABLE>Ok you will have to cut the front crossmember for the 4-1, I had that **** and it was a pain to get it to fit with the stock CM. I don't recommend it, it's way too low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">The billet hasport mounts require you to cut the factory hood a hair. </TD></TR></TABLE>
Would this apply if I have an EF8 front end conversion? (I pretty much have all the pieces required for the front end except the hood & corners.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">
This is all from my experience built on my CRX</TD></TR></TABLE>Thanks for the good information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1_Civic_EX »</TD></TR><TR><TD CLASS="quote">Would this apply if I have an EF8 front end conversion? (I pretty much have all the pieces required for the front end except the hood & corners.)
Your fine then. Ryan
</TD></TR></TABLE>Your fine then. Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1-ED8 »</TD></TR><TR><TD CLASS="quote">Do I have to go with the 90-91 ex knuckles or can I use SI knuckles instead?</TD></TR></TABLE>
When you say SI are you talking about 2000 Si or CRX Si??
If your talking about the CRX Si(9.5") then you not bother, you have to pay for another knuckles anyways so why not get bigger brakes??
I can't answer the 2000 Si knuckles cause I am not familiar with the offset, but the brakes are 10.2".
YES you can use gsr/99si/itr axles
I am using 94+ gsr axles in my ef hb si b18c1 gsr tranny hasport hydro kit.
Brian of hasport is also using stock gsr axles.... (makes you wonder why people would want to get the custome axles that hasport reccomends for the hydro swap)
there are pros and cons of both. I can say i'd rather get a set of napa lifetime warentee GSR axles... hehe
Agreed.
Agreed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">When you say SI are you talking about 2000 Si or CRX Si??
I was refering to the crx/civic si/dx knuckles, sorry. But ya if you can find the 90-91 civic ex, get those!!!
Squallie
Jun 12, 2005 07:54 PM
B18C1-ED8
16
Feb 21, 2005 01:03 PM
Black R
Oct 16, 2001 06:18 AM
