installing itr piston in b16
Old Jul 25, 2004 | 10:35 AM
DubyaAye's Avatar
Default installing itr piston in b16
i just blew my motor on my 99 civic si and was wondering do i have to shave part of the rods to fit some itr pistons in it. btw can i still pass smog with it? thanks in advance.
Old Jul 25, 2004 | 10:38 AM
Octoman's Avatar
Default Re: installing itr piston in b16 (DubyaAye)
ITR pistons will get you a lower CR, are you looking to lower it? CTR pistons and JDM B16 pistons are the only factory pistons that will raise your compression. I am pretty sure of this. Other than those you can always go aftermarket.
Old Jul 25, 2004 | 10:45 AM
electronb16si's Avatar
No you have the ITR pistons confused with CTR pistons. The CTR are the ones you want and yes some machining to the rods is necessary to fit correctly.
Old Jul 25, 2004 | 10:48 AM
DubyaAye's Avatar
Default Re: (electronb16si)
oh ok, will i still be able to pass smog with the ctr pistons?
Old Jul 25, 2004 | 10:57 AM
That I don't know. But I don't see why just raising the compression ration a little would effect emissions. Down here in FL theres no such thing as smog anymore so I have no idea about the restrictions, sorry.
Old Jul 25, 2004 | 08:20 PM
DubyaAye's Avatar
does anybody in ca knows?
Old Jul 25, 2004 | 09:20 PM
Turbogixxer's Avatar
Default Re: (DubyaAye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">does anybody in ca knows?</TD></TR></TABLE>
I would not say it will not past, but it will make it harder.
Old Jul 26, 2004 | 08:09 AM
DubyaAye's Avatar
Default Re: (turbogixxer)
how about the jdm b16 pistons. its going to be a spare motor incase i cant get a hook up for my smog later on.
GSR_hatch936
11
Jan 10, 2008 12:06 PM
greasemonkeys
Jan 7, 2005 06:41 PM
palmeref9
Jan 28, 2004 08:25 PM
mist sITR
Feb 25, 2003 09:00 AM
