HOW MUCH NITROUS CAN I RUN
HOW MUCH NITROUS(DIRECTPORT) CAN I RUN IN MY LS/VTEC MILD BUILD NEW VALVE DUAL SPRINGS RETAINER EAGLE RODS AND JE PISTON..SO HOW MUCH NITROUS YA THINK I CAN RUN............................................... .................
http://WWW.TEAMKINETIC.COM
Just to let you know block guards are not very safe for ur engine, there was someone on this board a couple years ago whose engine caught on fire because he was sprayin and had a block guard, i believe they raise the temperature of ur engine alot.
Tom
Tom
I'm running 150shot on my LS, almost same mods. It's not tuned, so I dunno how safe it is, but I haven't had any problems yet and it's been 2yrs.
100 to 125 shot is not bad. u should be prepared for it tho. some colder plugs, a large plenum intake manifold, good free flowing headers, and a 2.5 inch exhaust will be good. oh and most importantly some kind of ignition tuning wouldnt hurt. msd btm at least or uberdata. i believe there is nitrous control for it out but dont quote me tho not 100% good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilk »</TD></TR><TR><TD CLASS="quote">150 shot on a ls motor i think thats too much</TD></TR></TABLE>
does it matter what motor it is?
would it be ok if it was B16 or gsr?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC »</TD></TR><TR><TD CLASS="quote">
mainly on compression ratio i would think... higher compression ratio would be more prone to detonation under a higher shot of nitrous then a lower compression ratio
</TD></TR></TABLE>mainly on compression ratio i would think... higher compression ratio would be more prone to detonation under a higher shot of nitrous then a lower compression ratio
