help right now please
B16 in a STD
just put in a 255 walbro. Now the car hasnt been turned on inlike 5 months. But im using a Red Top, And it reads 12.28 volts when its hooked up and when it out. (its relocated in the back. But Everything gets power, headlights and all.
When i turn the key to ON only the battery light comes on. No Enging light nothing just the battery. Wtf? There is no power to the sender unit.
are you getting power at the starter? check with your multi meter at your starter. check the red lead on the 12mm nut and the black lead ground to the chassis. if there is power there than get a 10 gauge wire and jump the 12mm bolt to male trigger on the starter. if the car starts then you know you can start working backward from there.
actually i phrased that wrong.. if it starts then the batterey is good and you look elsewhere. if it chokes or doesnt start it may be the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">where? </TD></TR></TABLE>
in the fuse box in the engine bay.
ok it was just a missing fuse...
but my new fuel pump wont turn on. does anyone know how much power should be going to the sender unit? and what wires have power, Only one wire showed having slight power...
EM1Hero
45
Jul 29, 2013 07:04 AM
EK_kidd
Jul 10, 2008 07:32 AM
Lude@Heart
10
Jul 27, 2006 04:52 AM
CivicHB89
Dec 8, 2004 06:47 PM
