car won't start unless I push start it
99 civic ex. It won't start.. I got power cuz my radio and windows and stuff work. And its not my alt.. I kno its my starter.. Will this be a trouble fixing?
Re: car won't start unless I push start it (EK_kidd)
Super easy to replace actually...prolly just your intake and a couple other hoses and you will be all set, just 2 or 3 screws i dont remember exactly but it is not hard at all.
it happened to me. Check the little wire that connects to the Starter. The starter recieves 2 cables, the 12 V power straight from the battery, and the signal cable, which is a lot smaller, with a female tip at the end. Sometimes it wiggles loose. Push it back in, turn ur car on, come back here on H-T, and tell us it worked Good luck!
Re: (Juan_Mitosis)
Thanks a lot. I'm off 2day so I'm going to check it out. lmao I have my car parked on a ramp so I don't have to push it.
I had the same problems, changed out my starter and everything. The ground that runs from the battery to the engine bay was near rotted off. It looked OK at a glance. I went to the local junkyard and snagged one, problem solved.
elpermgrande
08-09-2002 06:43 AM
