Harmonic balancer?
OK last night my A/C locked up. I drove the car for a while until it smoked. Cut the A/C belt off and drove it for another hour or so.. While going on the highway my RPM stuttered and droppedto 0 , the car loss power temporarly. This happend 3-4 times going home.
I was wondering what would cause that.
Can the locked A/C cause the harmonic balancer to go bad?
I was thinking distributor coil.
No taking the A/C belt off will not cause it to go bad. Honda uses the same crank pulley for every engine. Some cars dont come with A/C or PS so y should that same motor and same crack pulley go out of balance just by cutting the a/c off. something else happened
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Honda uses the same crank pulley for every engine.</TD></TR></TABLE>
That's not true. Crank pulley styles and weights varried for different engines
thehatchninja
Jul 13, 2008 10:04 PM
sickerhatch
Sep 28, 2005 06:24 PM
