94 civic EX tranny swap (98 tranny) now linkage feels off? 5th gear almost impossible
Old Jul 23, 2004 | 06:02 PM
ArchAngel Sabastian's Avatar
New User
Default 94 civic EX tranny swap (98 tranny) now linkage feels off? 5th gear almost impossible
Did a tranny swap in a 94 civic with a 98 tranny and now the linkage feels like its wrong do i need to use the 98 linkage? some hlp plz
Old Jul 28, 2004 | 10:03 AM
Dasavior's Avatar
Default Re: 94 civic EX tranny swap (98 tranny) now linkage feels off? 5th gear almost impossible (ArchAngel
Hlp plz
Old Jul 28, 2004 | 10:14 AM
Deemeetree's Avatar
Electrician
Are all the bolts tightened? Did you put back the "bitch pin"? If so, what is the condition of your shifter bushings?
Old Jul 28, 2004 | 03:32 PM
Dasavior's Avatar
Default Re: (Dimi)
all bolts tight, yes the... "bitch pin" is back in and the clip around it shifter bushings look ok. Its as if the linkage leaves the shifter too far "forward" ie when its in nuetral the shifter looks and is angled like it should be in first gear.
Old Jul 28, 2004 | 03:47 PM
Discosteak's Avatar
maybe you got a fucked up tranny?
Old Jul 30, 2004 | 05:36 AM
Dasavior's Avatar
so im assuming that there is no difference inbetween the 93 to 98 linkages?
Old Jul 30, 2004 | 05:48 AM
civic-4-ges's Avatar
Default Re: (Dasavior)
I ampretty confident you would need the linkage to match your chassis code, so I don't think you would need to swap it out.
Old Jul 30, 2004 | 07:05 AM
Phantom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasavior &raquo;</TD></TR><TR><TD CLASS="quote">all bolts tight, yes the... "bitch pin" is back in and the clip around it shifter bushings look ok. Its as if the linkage leaves the shifter too far "forward" ie when its in nuetral the shifter looks and is angled like it should be in first gear.</TD></TR></TABLE>
sounds like you installed the shifter backwards, I've done it before, it's easy to fix
Lei Siew Long
Feb 6, 2004 05:36 AM
743power
17
Oct 25, 2003 06:04 AM
743 Stunna
Oct 19, 2003 09:58 AM
StrangerWitCandy
May 31, 2003 06:38 PM
StrangerWitCandy
May 28, 2003 02:14 PM
