changing the timing belt in a 98 si
Old Jul 23, 2004 | 04:59 PM
stevescivic's Avatar
Default changing the timing belt in a 98 si
has anyone here sucessfully removed the crankshaft bolt from a 98 civic Si (Canada model)? Its the soch vtec D16 engine. I don't have the crank pulley holder and I don't have access to a really really powerful air tool other than the impact wrench I have at home which of course isn't strong enough.
Suggestions?
Thanks
Old Jul 23, 2004 | 05:02 PM
ABK's Avatar
ABK
Default Re: changing the timing belt in a 98 si (stevescivic)
put the car on the ground, put the car in first get a huge breaker bar and hope it will break loose.
Old Jul 23, 2004 | 05:08 PM
EX-T's Avatar
You don't have to take the crank pulley of to change the timing belt!
Old Jul 23, 2004 | 05:15 PM
Default Re: changing the timing belt in a 98 si (DSeriesBKilla)
what do you mean you don't have to take the pulley off to change the belt. All honda's have to have the pulley removed to get at the t-belt.
Hmm never thought of that before... putting the car in 1st gear. Brilliant!
Old Jul 23, 2004 | 05:37 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to take the crank pulley of to change the timing belt!
are you on CRACK????
you must remove crank pully to get the plastic cover off timing belt which means you must take crank pully off.....
since YOU DON"T KNOW WHAT YOU ARE TALKING ABOUT!!
Old Jul 23, 2004 | 05:41 PM
EJ8 D15Y8's Avatar
Please do not reply if you have nothing to offer !
Heres what I do. If I have a pal present.
I tell him to sit in the car, put it in 5th and push on the brake pedal as hard as possible.
And yank that crank pulley as hard as possible with a breaker bar.
I usually just get a breaker bar with another 5-10 foot pipe on the end to make it easier.
Should break right loose. Good luck.
Old Jul 23, 2004 | 06:42 PM
smokinsi's Avatar
Default Re: (EJ8 D15Y8)
I drove mine to honda they put it on the lift broke it loose with an impact and sent me on my way for free.
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
hmtcrxsir
Dec 22, 2009 10:21 AM
EG2Driver
Jun 15, 2006 07:24 PM
NeriVTEC
Mar 19, 2005 01:56 PM
kicker1_solo
Apr 21, 2004 11:50 PM
