Check engine light once again:(
Old Jul 23, 2004 | 04:54 PM
hondaracing1's Avatar
Default Check engine light once again:(
well first off if you ride in vtec range not close to 7k but inbetween 5500-6500 can it make it throw a code?.......THis has happened before and i got it checked and it was vtec system malfunction and i reset my ecu havent had a problem since untill now. But now after the check eng. light came on if you go up to 6k the car sputters and about stalls out. What does this mean? what can i do to fix it?
I dont care about punctuation or spelling
Old Jul 23, 2004 | 05:11 PM
EX-T's Avatar
Default Re: Check engine light once again:( (hondaracing1)
Go to an AutoZone and get your ecu scanned and see what code it's throwin'.
They do it for free.
Old Jul 23, 2004 | 05:36 PM
Default Re: Check engine light once again:( (DSeriesBKilla)
i did....it came up to fuel/air metering and the code i forgot what it was p1259 somethin like that and it was VTEC SYSTEM MALFUNCTION so i know what it is but why do i keep getting this problem and why is it acting up at 6000 rpms?
Old Jul 23, 2004 | 05:39 PM
chad's Avatar
Moderator
do you have oil in the car? is it the proper level??
Old Jul 23, 2004 | 05:41 PM
Deemeetree's Avatar
Electrician
Indeed. The VTEC system doesn't work if you don't have enough oil in your crankcase.
Old Jul 23, 2004 | 05:50 PM
Default Re: (Dimi)
yep oil was changed and filled with i think 4 quarts 4 days ago
Old Jul 23, 2004 | 06:56 PM
smokinsi's Avatar
Default Re: (hondaracing1)
check it cuz its supposed to be more than 4. Low oil will affect vtec.
Old Jul 23, 2004 | 07:12 PM
Default Re: (smokinsi)
even if it is supposed to be more then 4 it isnt by alot and we just put it in there and i know it isnt burning that much oil and there are no oil leaks already got that checked.
vtec8804
Oct 20, 2006 07:56 AM
Cedor
Jun 4, 2005 06:51 PM
kampucheakid
Jun 1, 2005 09:28 PM
Blake97GSR
Nov 5, 2003 12:58 PM
vteg
Sep 25, 2002 08:08 PM
