z6 cam in a y8 head
Old Jul 23, 2004 | 09:45 AM
jdm_eg's Avatar
Default z6 cam in a y8 head
hey guys my cam that is in my y8 just snaped off at the end were the distributoris so i was wondering if i can put a d16z6 cam in a d16y8 head because i can get it for really cheap
Old Jul 23, 2004 | 10:17 AM
sohc_boy's Avatar
Default Re: z6 cam in a y8 head (jdm_eg)
it will fit, cam timing is off 5 deg though.
Old Jul 26, 2004 | 09:07 AM
jdm_eg's Avatar
Default Re: z6 cam in a y8 head (sohc_boy)
so should i set the cam timing off alil then are what should i do also does ne body no the torque specs for the bolts that connect the valve springs n rocker arm etc.
Old Jul 26, 2004 | 12:03 PM
RyanEJ8's Avatar
You need an adjustable cam gear and you need to advance it 5 degrees to get a normal range of ignition timing adjustment on the distributor. I have the torque specs at home, I can get them for you later if you need. I'm at work right now.
Old Jul 26, 2004 | 02:32 PM
jdm_eg's Avatar
Default Re: z6 cam in a y8 head (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">You need an adjustable cam gear and you need to advance it 5 degrees to get a normal range of ignition timing adjustment on the distributor. I have the torque specs at home, I can get them for you later if you need. I'm at work right now.</TD></TR></TABLE> aite sounds good just reply on here agian weneva you get home with the specs thanx man
Old Jul 26, 2004 | 03:05 PM
ARIZONA's Avatar
The timing will be off by one sprocket tooth (4.75 degrees). So basically, you can skip a tooth on the sprocket, adjust for 5 cam degrees below TDC and adjust ignition timing to put it back at TDC.
Old Jul 26, 2004 | 03:34 PM
jdm_eg's Avatar
i need the torque specs for where the rockers connect up with the cam to the head not the head studs just wanted to make sure you guys no because i dun wanna confuse u
Old Jul 26, 2004 | 05:04 PM
RyanEJ8's Avatar
Default Re: (jdm_eg)
The 8mm bolts are 16 ft lbs and the smaller 6mm bolts on the end by the cam gear are 9 ft lbs. Start with the bolts in the middle and work your way to the outside.
Old Jul 26, 2004 | 08:13 PM
jdm_eg's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">The 8mm bolts are 16 ft lbs and the smaller 6mm bolts on the end by the cam gear are 9 ft lbs. Start with the bolts in the middle and work your way to the outside.</TD></TR></TABLE> aite thanx alot man n thanx to the other guys who helped me out
austen95
Mar 12, 2018 06:55 PM
alexsracing
Feb 17, 2005 04:06 PM
SOHC_MShue
Nov 7, 2003 04:57 AM
Daniel
17
Oct 24, 2003 09:55 AM
DV98CVC
17
Oct 2, 2003 09:00 AM
