your opinions on ls set up
i just bought a spare ls engine for my 94 4 door.. im going to boost it this fall
im looking for 10-14 lbs of boost.. can i get away with that much boost with the following set up??
the head is now on its way for porting/polishing.. their also installing skunk2 valve springs..i know the ls head doesnt flow for anything.. but every bit counts.. i got a good deal on the work..350 for everything..
inlinepro 3mm head gasket.. now the 3mm h.g. drops the b16a from 10.2 down to 9.4 cr.. so im guessing 8.7 with arp head bolts,new water pump,timing belt
im taking the car to inline to have the turbo work done.. i just wanted to get an idea of psi i can run..
thanks
