Anyone build Non-Vtecs?
Old Jul 22, 2004 | 10:23 AM
hybrid_vtec's Avatar
Default Anyone build Non-Vtecs?
Does anyone try to be different and build non-vtecs? Im just curious as to how far you can go with a non-vtec!
Old Jul 22, 2004 | 10:26 AM
ExospeedAMcrx's Avatar
we still do alot of non-vtec setups for customers. D and B series. Theres plenty you can do from the bottom end to head work and cams. The Non-vtec motors have been forgotten but they still are a good choice for building up a motor.
Old Jul 22, 2004 | 12:13 PM
onemanlan's Avatar
Default Re: (exospeedAMcrx)
My friend is buidling up his A20A3(think thats the code). Not all motor, but hes building it up.
Old Jul 22, 2004 | 01:08 PM
StyleTEG's Avatar
Default Re: Anyone build Non-Vtecs? (hybrid_vtec)
You can get the same range that most people get with their vtec engines.
Its just the 5-10% that do full aggresive builds that go above and beyond what a non-vtec is capable of.
Old Jul 25, 2004 | 12:08 PM
Where can I dig up sum information on non-vtecbuilds so I can get sum ideas on which route i may choose to go!
Old Jul 25, 2004 | 01:31 PM
chris_m's Avatar
* B A N N E D *
Default Re: (hybrid_vtec)
d or b
Old Jul 25, 2004 | 05:56 PM
Grey_DA93's Avatar
Default all motor ls
You can get a lot of power out of a non-vtec motor, however you do lose daily driveability if you go for max power. you only have the single lobe on the cams to control the valves, and so you lose the idle quality you could get with a similarly built vtec motor. My ls runs 133.8 hp at the wheels and 124 or 128 tq on stock cams...
Old Jul 26, 2004 | 09:34 AM
Default Re: (alld16a)
B-series
Old Jul 26, 2004 | 10:14 AM
USDMGD3!'s Avatar
here's a couple of threads
https://honda-tech.com/zerothread?id=520581&page=1
https://honda-tech.com/zerothread?id=677470
https://honda-tech.com/zerothread?id=926533
https://honda-tech.com/zerothread?id=506351
b20
siregcivic
18
Jul 2, 2011 04:17 AM
lriver0001
Apr 13, 2011 09:20 PM
Mach1
Nov 11, 2004 07:38 AM
SinTeg21
Sep 28, 2003 10:11 AM
milanoGSR
17
Sep 16, 2003 09:01 PM
