what do you guys think? This turbo too big?
Old Nov 25, 2001 | 06:52 PM
paulzy's Avatar
Default what do you guys think? This turbo too big?
I remember DrealGSR saying something about the 7bladed compressor wheels have a smaller trim...
WIll I be struggly with this turbo on an Ls/vtec(fully built)?
Here's the link: http://cgi.ebay.com/ebaymotors/aw-cg...247873&r=0&t=0
SHOULD I GO FOR IT? It will need a t4 flange on the manifold right?
[Modified by Slow_ass_4dr, 7:54 PM 11/25/2001]
Old Nov 25, 2001 | 07:30 PM
Dee's Avatar
Dee
Default Re: what do you guys think? This turbo too big? (Slow_ass_4dr)
Damn .. I can't see it because ebay is blocked!! Actually what I said was the 7blade 7 splitter T04B compressors spools faster but can not flow as much volume as the T04E. As long as it meets your HP and pocket money requirements and doesn't cost much it will be a good purchase. I'll look at the link when I get home tonight!
Old Nov 25, 2001 | 07:35 PM
MiraiZ's Avatar
eeeek....dude! that thing is rusted pretty badly...will need a lot of work. The size should be ok though
Old Nov 25, 2001 | 07:37 PM
turbocoupe's Avatar
Default Re: what do you guys think? This turbo too big? (MiraiZ)
pretty rusty...
Old Nov 25, 2001 | 09:43 PM
InfamousDX's Avatar
the size is fine... but look at that rust
Old Nov 25, 2001 | 10:40 PM
Dee's Avatar
Dee
Default Re: what do you guys think? This turbo too big? (InfamousCivic)
look at that nasty ex blade! That thing has to have a blown oil seal on the ex side. The rust doesn't matter since it can be knocked of in 30 secs with a sand/bead blaster. You might want to let this one go but atleast try asking about the OILY ex blade! That's also an on-center T4 housing there! If you aren't gonna see lots of track duty this is not the turbo for you. The biggest T4 housing you want on a streetable 2.0 liter or below 4cylinder is an AR.58 with the AR.50 or HKS AR.40 being better choices.
SO if you buy it you will need a rebuild kit for the seals and a T3 housing and blade if you want to make a T4/T3. For the price of those parts you might as wheel just buy a new one that comes with a limited warranty.
Tell the seller the AR for the compressor is stamped inside of the outlet tube to the IC and the ex AR is stamped inside of the inlet by the flange.
[Modified by drealgsr, 11:43 PM 11/25/2001]
Old Nov 26, 2001 | 11:36 AM
paulzy's Avatar
Default Re: what do you guys think? This turbo too big? (drealgsr)
thanks drealGSR....
Glove
Dec 10, 2009 07:24 AM
xander1100
Aug 8, 2009 11:44 PM
SpoonyGSR
Aug 23, 2004 01:43 PM
Spoold_R
Sep 12, 2003 08:13 AM
paulzy
Nov 17, 2001 04:11 PM
