Code 1362... crank position sensor
Old Jul 21, 2004 | 10:03 AM
Ukraine Train's Avatar
Default Code 1362... crank position sensor
My brother's CR-V is throwing this code. According to the Mitchell manual I looked at it's the crank position sensor and the only way to fix it is replace the distributor. Can anyone confirm this, or have any experience with this code?
Old Jul 21, 2004 | 12:16 PM
JimBlake's Avatar
Default Re: Code 1362... crank position sensor (Ukraine Train)
Yeah, it's in the distributor. First check the wiring connection to the distributor. If you're lucky something's loose or corroded.
I've heard you can't get those sensors except to buy a distributor. But I bet you can buy a distributor with or without a coil, ICM, cap, rotor...
eversole6
Jun 2, 2014 10:15 PM
JDM6spdEKAY
Dec 12, 2006 07:14 AM
Reddog
Aug 28, 2002 01:24 PM
Spade
Jul 30, 2002 02:05 PM
REDBARON
Jul 8, 2002 07:07 PM
