Question about ITR Gearbox...
Old Jul 20, 2004 | 08:48 PM
REDTOPAlchemy's Avatar
Default Question about ITR Gearbox...
I have been noticing for a while now that when I am driving my R and I try to downshift into first (at 2-3 miles an hour....an absolute crawl...usually when I go over speedbumps or dips) it won't go without a fuss...sometimes a little slapping sound but not like a grind. I kinda have to force it in which I'm very reluctant to do. Is this the way the ITR manual transmission is built, or has something gone south in my gearbox?
Old Jul 20, 2004 | 08:51 PM
uNF$@#!'s Avatar
Default Re: Question about ITR Gearbox... (PYXITR)
1st gear is not syncronized, so you either rev match, or deal with the issue
Old Jul 20, 2004 | 09:16 PM
Default Re: Question about ITR Gearbox... (Captain Commando)
Thanks for the info. I see...so my other question for you would be:
Is it damaging the gearbox when you don't rev match and try to shift into first at a slow speed? If it is...in what way is it damaging the manual trans.?
Old Jul 21, 2004 | 03:18 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote"> 1st gear is not syncronized</TD></TR></TABLE>
You sure on that?
Old Jul 21, 2004 | 05:21 AM
rainman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote"> 1st gear is not syncronized, so you either rev match, or deal with the issue </TD></TR></TABLE>
If that was the case, how do you explain shifting into 1st at a dead stop without grinding? A non synchro box will always make a ton of noise when doing this. I'm really curious about this.
Old Jul 21, 2004 | 08:34 AM
Seedc2's Avatar
Default Re: Question about ITR Gearbox... (rainman)
i thought reverse didnt have synchros?
Old Jul 21, 2004 | 08:35 AM
PM-Performance's Avatar
every manual car i have ever driven has been like that.
Old Jul 21, 2004 | 10:09 AM
01-1293's Avatar
Default Re: Question about ITR Gearbox... (itr206)
100% normal.......sometimes a quick clutch down into 2nd gear and then 1st gear will do the trick...helps line the teeth up
btw 1st gear does have a syncro
don't force it in...if it's not going into gear there is a reason
Old Jul 21, 2004 | 10:19 AM
Default Re: Question about ITR Gearbox... (01-1293)
So what possible damage results from forcing it into gear...with the clutch all the way...just gears not meshed?
Old Jul 21, 2004 | 11:30 AM
Anybody?
Old Jul 21, 2004 | 01:29 PM
01-1293's Avatar
thats the syncro grinding......if you really ream on it eventually you will have to replace the syncro
Old Jul 21, 2004 | 01:40 PM
BERT-O's Avatar
1st gear does have synchros, its 1-2 set, then you have 3-4 set and last 5-R sets.
As far as your questions goes, change your fluid if you havn't had so. Also check the fluids on the slave cylinder, those tend to go bad, no matter what mileage of the car have!
Old Jul 21, 2004 | 01:41 PM
I see. Can you define "really reaming on it."
screaminj
Honda Fit
Oct 29, 2007 05:57 PM
MOVE OVER
Mar 12, 2005 02:12 PM
b20vtecEK
Mar 1, 2004 12:40 PM
Loveless
Jun 23, 2003 09:40 PM
comptechgsr
May 9, 2003 03:19 PM
