STR cam gear problem?
Old Jul 20, 2004 | 09:40 AM
BillB's Avatar
Default STR cam gear problem?
I just got some STR cam gears for my b18c5 powered CRX mrk2 & when torquing up the last locking bolt (to 10lb's ft) its stripped the threads
STR's website & the sticker on the cam gear says torque to 10-12lb's/ft so it got me thinking has anyone else has the same problem before?
I've emailed STR from their website a few days ago now but havn't heard anything back yet
BillB
Old Jul 20, 2004 | 01:41 PM
AzG35's Avatar
Default Re: STR cam gear problem? (BillB)
i've had mine for over a year now, and haven't had any problems at all. I've done many adjustments on them as well. Probably calling STR would be the best bet.
Old Jul 20, 2004 | 03:12 PM
krazie1's Avatar
BANNED
Default Re: STR cam gear problem? (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">i've had mine for over a year now, and haven't had any problems at all. I've done many adjustments on them as well. Probably calling STR would be the best bet.</TD></TR></TABLE>
yeah I hope I don't get this prob as I am installing mine this weekend on my cams
Old Jul 21, 2004 | 02:50 PM
ranta18's Avatar
Default Re: STR cam gear problem? (krazie1)
Is it the old design or brand new? They've had problems with the old ones, but the new ones should be good to go.
Old Jul 21, 2004 | 04:48 PM
BluePrintmfg.com's Avatar
Banned
Default Re: STR cam gear problem? (ranta18)
we only use JG cam gears or skunk2 cam gears, I have seen many other brand cam gears have the same problem with cam gears, we never get this problem with JG or skunk2
Old Jul 21, 2004 | 05:29 PM
TOM J's Avatar
Old Schooler
Default Re: STR cam gear problem? (11sec.ALL MOTOR)
I have had my STR cam gears for about 4 years and still no problum.
Give them a call so they can fix this for you.
Old Jul 21, 2004 | 05:43 PM
TECH43 RACING INC.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11sec.ALL MOTOR &raquo;</TD></TR><TR><TD CLASS="quote">we only use JG cam gears or skunk2 cam gears, I have seen many other brand cam gears have the same problem with cam gears, we never get this problem with JG or skunk2 </TD></TR></TABLE>
you said "cam gears" 4 times in one sentence.
Old Jul 21, 2004 | 06:08 PM
rodimus's Avatar
Default Re: STR cam gear problem? (TECH43 RACING INC.)
are these the old or new str cam gears?
Old Jul 21, 2004 | 06:20 PM
H22ek4's Avatar
Default Re: STR cam gear problem? (EVOL)
I had the new design on my motor for 40miles then all of the bolts on the exhaust cam came loose, had to tow the car to the shop that built my motor. 3 miles later, after both of the cam gears were tighten and torque down to specs, all of the bolts on my intake gear came off causing it to advance like 15 degrees!!! All of this happen when i was breaking in the motor, lucky nothing else was broken. Now i'm running skunk2 .
Old Jul 22, 2004 | 01:20 AM
BillB's Avatar
Default Re: STR cam gear problem? (H22ek4)
The cam gears I have look just like the ones on the STR website so I guess thats the new ones?
I'm over in the UK so its a PITA to get tuning parts at ok prices
I took the other gear off my motor just incase, gona see what STR say in there next email then I'll have to make my mind up what to do as I have Jun3's if they slip to max adjustment its not gona be pretty
Thanks for the replys btw I think this is my longest post ever on HT
BillB
LSR-Abuser
Oct 1, 2007 09:11 AM
Mugencrxsir1
Mar 2, 2006 02:55 PM
pwrofdrm
Jul 24, 2004 09:23 PM
Boost2NA
Apr 20, 2004 05:47 PM
sshaikh01
22
Aug 22, 2003 04:32 AM
