How do you install a Cam
I'm trying to take the cam gear out, but as we all know its torqued down.
How do you guys open your cam gear, I tried to stick a flat head in the camshaft, and than turn the nut to open the cam gear, it won't move.
any sugestions
any sugestions
Re: How do you install a Cam (slowman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman »</TD></TR><TR><TD CLASS="quote">Well are you having trouble taking the nut off? Or the actual cam gear?</TD></TR></TABLE>
the nut
the nut
Re: (bushfreakz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bushfreakz »</TD></TR><TR><TD CLASS="quote">impact with a twisty socket will take it off..</TD></TR></TABLE>
The head is out of the car and laying on the ground.
I took way too long
Re: (slowman)
Refer to this for more info...
http://www.geocities.com/slowmanef/d16a6cam.html
It's a write up I made, I know it's for a sohc, but it may help you out?
Good luck.
Good luck.
Re: (slowman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman »</TD></TR><TR><TD CLASS="quote">Put something through one of the holes in the cam gear to stop it from turning, so that whatever you put through hits the head and it won't move. Then instead of turning the ratchet, just give really hard taps to it to break it loose.
HTH??</TD></TR></TABLE>
The cam which is on there is solid, no holes in it.
Re: (slowman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman »</TD></TR><TR><TD CLASS="quote">Through one of the holes or openings on the cam gear.</TD></TR></TABLE>
its not a honda which i'm working on, and the cam is solid, no holes in it, its a solid, circle.
Re: (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">take the cam out... Hold the cam in your hand with a towel wrapped around it, and impact the bolt off...</TD></TR></TABLE>
I grapped a dirty towels, folded them up, wraped them around the cam gear held it tight, and tried to open the nut. no luck.
Re: (sshaikh01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">
were you using an impact gun???
Re: (EG2 SiR)
What if you use a belt and strap it around the cam gear really tight? A belt that holds your pants up. Same principle as that rubber Craftsman wrench. Sounds crazy but it should work.
Re: (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel »</TD></TR><TR><TD CLASS="quote">What if you use a belt and strap it around the cam gear really tight? A belt that holds your pants up. Same principle as that rubber Craftsman wrench. Sounds crazy but it should work.
When I did not have an impact gun I did something similar to this idea. I was changing the timing belt, so I cut the old one in half.... Wrapped it around the cam gear, covered the cam with a couple towels, then drove a tire ofer the end of the timing belt... it held that isht tight and I was able to get the bolt off! DIY man!!! Macguyver style!
Re: (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Quote, originally posted by wilsel »
When I did not have an impact gun I did something similar to this idea. I was changing the timing belt, so I cut the old one in half.... Wrapped it around the cam gear, covered the cam with a couple towels, then drove a tire ofer the end of the timing belt... it held that isht tight and I was able to get the bolt off! DIY man!!! Macguyver style!</TD></TR></TABLE>
no i don't have an impact gun just a plain old craftsman rachet.
Thanks for the idea, guys i'll give that a try.
Re: (Zexed SiR)
if you are having that much trouble getting it off, go to a local auto shop. im sure they could get off for you.. otherwise go buy an impact, its a great tool to have. good luck!
Re: How do you install a Cam (sshaikh01)
i know its not DOHC, but here is a good write up for installing a cam in a SOHC http://pub161.ezboard.com/fbse...topic
Re: (davken1102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davken1102 »</TD></TR><TR><TD CLASS="quote">if you are having that much trouble getting it off, go to a local auto shop. im sure they could get off for you.. otherwise go buy an impact, its a great tool to have. good luck!</TD></TR></TABLE>
he might need an aircompressor along with the 99 dollar impact gun set. not to mention impact sockets. (my next goal...mMmm)
Re: (all stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">
he might need an aircompressor along with the 99 dollar impact gun set. not to mention impact sockets. (my next goal...mMmm)</TD></TR></TABLE>
Great investment! plus you be able to do alot more much quicker
