Best Cam Gear Design? Have'nt found an answer!
I was wondering if an cam gear design is really better than any other? If you torque you bolts correctly you should'nt slip right? I've heard that 3 bolt cam gears are fine, and other hate them, then others swear by the 4 or 5 bolt design. Is any really superior? From a designe stand point I can see that the more bolts you have, techniquely the more holding potential. Please give me your opinions and preferences. thanks
Re: Best Cam Gear Design? Have'nt found an answer! (Mugencrxsir1)
i have seen numerous 3 bolt cam gears slip, strip, you name it.
i rock the full-race cam gears......tons of bolts
Re: Best Cam Gear Design? Have'nt found an answer! (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">i have seen numerous 3 bolt cam gears slip, strip, you name it.
i rock the full-race cam gears......tons of bolts </TD></TR></TABLE>
Yeah, I like their design, but the JGE cam gears are the same exact design, and are less expensive and come in 4 different colors. So I'll take your word and go with the 6 bolt design.
