Coolant in Oil I need some help!
Old Jul 19, 2004 | 06:15 PM
G2Crash's Avatar
Default Coolant in Oil I need some help!
hey, I have a freshly built motor, new headgasket, I got the head pressure tested and vaccum tested, and check surface with a straight edge. and now I find out I'm mixing real bad. I drained the oil and there's a lot of water in it and it's a little milky, but I had more water than coolant in there. I'm guessing that I have a blown water jacket or something, because when I bought the block the ring lands on the pistons were warped and the rings were real bad.
Is my block toast? or is there anything else I can look for? any help would be great. thanks
Old Jul 19, 2004 | 06:46 PM
zensoku207's Avatar
do a compression test, flush the system, check all gaskets that you can get to, refill and see how it turns out.
does the head gasket leak?
Old Jul 20, 2004 | 03:07 AM
G2Crash's Avatar
ya the corner of the Headgasket leaks under the Vtec Solenoid.
I'm going to do a Compression check today and look over everything again.
1320london
May 15, 2015 06:47 AM
lilshady6796
15
Jan 13, 2009 05:40 PM
an2ny888
Jul 4, 2008 07:40 AM
boostedcivic37343
May 28, 2008 05:00 PM
tek_civic
Feb 16, 2006 06:43 PM
