injectors all the same?
Say I were to buy some 300cc injectors that were intended for a civic. Can I also use these 300cc injectors in my celica? This is not really a specific engine question. I am just trying to figure out if injectors are made specifically for every type of engine.
[Modified by hondur guru, 8:25 AM 11/25/2001]
it depends if you have a 0bd 0 car or a obd 1-2 car here are some that will work on both that around 300cc.
92-96 preludes 345cc and will work on pre obd cars.
97-00 preludes 280cc will work on obd 1/2 cars
no there are two types saturated and peak and hold you can tell the diffrence with a ohm meter one type has a higher restince not sure which one is higher though
Someone else care to anwser that for me ????
alot -most of car manufacturers dont use the same fuel rail. there are high impedence, low impedence. i wouldnt consider all injectors to be universal or transferable to other models.
It easy to test which injectors you have - just put a multimeter on resistance and put the probe on each of the 2 terminals of the injector (+ probe on one pin, - probe on the other). If it reads 2-3 ohms, you have a LOW IMPEDANCE, PEAK AND HOLD injector that requires a RESISTOR BOX. If the resistance reads 11-12 ohms, you have a HIGH IMPEDANCE injector that does NOT require a resistor box.
How much work is it to change the fuel injectors?? How much does it usually cost for parts and labour? I did an obd2 to obd1 swap, so does this mean I need to change my fuel injectors?
