reprogrammed chip into b16a2
Old Nov 23, 2001 | 05:27 PM
ben_vtec's Avatar
New User
Default reprogrammed chip into b16a2
if i fit a pals ecu with reprogrammed chip into mine and reset the ecu will it need dynoing or will it run ok without.
Old Nov 23, 2001 | 05:39 PM
eg6ajk's Avatar
Default Re: reprogrammed chip into b16a2 (ben_vtec)
why would you need a dyno....is only done to measure the power, to actually see if the chip made the power and if so where...also it can be used with other sensors to deterime exact mixtures, through out the session...
also by pluggin a new ecu, ecu will simply adjust its self...if you get codes (check engine) you know there is something wrong, right away...
Old Nov 23, 2001 | 06:01 PM
ben_vtec's Avatar
New User
Default Re: reprogrammed chip into b16a2 (eg6ajk)
ive also recently seen this viper jet thing which sprays a thin mist of water into intake valves whats the score with that ,its fairly cheap which leads me to believe it cant be up to much anyone had any experience with these or similar
Old Nov 23, 2001 | 06:03 PM
DragII's Avatar
25 Year Member
I don't like the that kit at all. there are more efficient ways of tuning your car.
Old Nov 23, 2001 | 06:14 PM
ben_vtec's Avatar
New User
Default Re: reprogrammed chip into b16a2 (DragIIcivic)
when i tried the chip in my car it seemed a bit better , vtec coming in 4800 rather than the stock 5800 but the rev limiter is now non existant and although i love screaming it to 9000 all day long it cant be healthy what are the options available
Old Nov 23, 2001 | 09:35 PM
HXMan's Avatar
You haven't floated your valves yet? Wow. Yea, that isn't healthy at all.
Old Nov 25, 2001 | 04:19 AM
ben_vtec's Avatar
New User
Default Re: reprogrammed chip into b16a2 (HXMan)
this post wasnt really by me but by neil_vtec. he wont be doing it again though coz i changed my password.
strange thing is its my chip that i will be giving him after i get my turbo. and he was writing the post as if he was me.....wierd.
elliascool
May 4, 2011 04:54 PM
Unseen Racer
Aug 29, 2008 08:37 AM
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
littlemracura
Aug 17, 2004 02:13 PM
5STAR3
Mar 20, 2004 04:40 PM
