Help....bleed abs
Right rear
Left rear
Right front
Left front
If it's 98-Spec then there is no separate procedure for bleeding the ABS system, since there is no separate reservoir.
If you have a pedal that's too soft after carefully bleeding, be aware that some people have had better luck bleeding the calipers with the motor running. According to them, this helps bleed the ABS system of burned brake fluid that might be trapped there.
I regard the information about the motor running as apocryphal, since I have not done it myself. I can usually get a decently firm pedal using the bleeding sequence I spoke of.
You might want to contact Willard Harris or Jack Harris about bleeding the ITR ABS. If anybody's ever been able to do it right, it'd be them.
Left rear
Right front
Left front
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">... some people have had better luck bleeding the calipers with the motor running. </TD></TR></TABLE>
More likely the engine vacuum helps to more fully and completely complete the bleeding process.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">Right rear
Left rear
Right front
Left front
I think it's actually completely backwards on the ABS equipped Integras as my helms states the bleeding procedure as:
front left
front right
rear right
rear left
My luck has been a bit better with the car turned on and getting the ABS pump to prime, meaning the driving wheels have to be moving like 10km/h before you hear the "BrrRrrrT" sound.
Edit: Can't find my helms anywhere.... bastard friends who borrow and never return.....
Left rear
Right front
Left front
front left
front right
rear right
rear left
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">
front left
front right
rear right
rear left
Thats how I bleed my brakes and so far no problems and a nice firm pedal up to date.
On the other hand, I have never bleed my brakes with the car on.
front left
front right
rear right
rear left
</TD></TR></TABLE>Thats how I bleed my brakes and so far no problems and a nice firm pedal up to date.
Hi guys..
I'm the guy that's in the problem..
While we where in the bleeding process,i was pressing the brake and JDM97R was bleedin the pipes.I wasn't sure enough how much i had to press the pedal,so i sort of pressed it all the way through!
Do you think i riuned the master cylinder?? I noticed that while the engine is off,the pedal is really firm....
Help pls..
Help pls..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm 98spec R »</TD></TR><TR><TD CLASS="quote">Hi guys..
Help pls..
No, you probably didn't ruin it. LOL...
However, it's true that when you are bleeding brakes, it's not a good idea to press the pedal all the way to the floor. 75% of the way is fine.
The problem with pressing the pedal all the way to the floor is that you are pressing beyond the normal actuation point for the brakes, which could mean you're pushing the seals past rough places, or even slightly corroded places that'll damage the seals.
I think I explained that right.
Help pls..
</TD></TR></TABLE>No, you probably didn't ruin it. LOL...
According to past posts, some people indicated they could never get it all the way bled without driving it. Actuating the ABS with the car moving seemed to free up bubbles in the ABS unit itself, that were impossible to get any other way.
They then repeated the bleed after the drive/ABS actuation, and everything was fine.
