Connecting rod caps stuck!
Old Jul 15, 2004 | 05:22 PM
RTW DC2R's Avatar
Default Connecting rod caps stuck!
Basically I cant get them off. I have ARP bolts in there, and have no problem taking off all the nuts. But when trying to pull the cap off, it only comes about halfway off the studs and then gets stuck. I tried to pry at it with a crow bar and other **** but no dice. Im trying to avoid damaging the crank any further than it already is. Any suggestions?
Old Jul 15, 2004 | 08:13 PM
IN VTEC's Avatar
Default Re: Connecting rod caps stuck! (RTW DC2)
We had the same problem with a set of rods too. We had to wrap and clamp them in a bench clamp, thread the nuts on partially, and then hit the studs with a dead-blow hammer. The trick is to get each side to wiggle out evenly so that one side doesn't bind as the cap comes off.
You might also try putting a slight chamfer on the inner radius of the rod cap holes on the side that mates to the upper half of the rod.
Old Jul 15, 2004 | 08:26 PM
RTW DC2R's Avatar
well it looks like the crank is worthless now, thats the main thing i was concerned about. I didnt want to damage it any further than it already is. But since is garbage Ill just bang the F out of the caps til they come off. Thanks
Old Jul 15, 2004 | 08:39 PM
Madspeed's Avatar
is the crank trashed because of how you took the caps off or was it already bad.....
i had this same problem with a B18c1 block about 2 weeks ago....i "beat" the caps off by "hammering" on the pistons...this pushed them out the top and forced the caps off.....so what im asking is " is my crank trash too"....it still has a near mirror finish...but what the hell caused the caps to do that....and i would assume that this means the rods are trash to no?
Old Jul 15, 2004 | 10:48 PM
Bbasso's Avatar
Wtf kinda luck you got???
Old Jul 15, 2004 | 11:36 PM
Opie's Avatar
Old Jul 16, 2004 | 04:36 AM
RTW DC2R's Avatar
the crank was already damaged from when my rod ripped through the block. Im told that if the journal is scratched, enough to feel it with your fingernail, its probably trashed. That tiny scratch will create a hot spot, and you will end up spinning the bearing anyway and risk further damage to the motor.
Old Jul 16, 2004 | 04:46 AM
PM-Performance's Avatar
Default Re: (RTW DC2)
even if the crank has scratches on the journals you can polish them out. i had it done already.
Old Jul 16, 2004 | 04:50 AM
RTW DC2R's Avatar
well mine has quite a bit more than a scratch. check my other thread for that mess.
Old Jul 16, 2004 | 05:55 AM
Madspeed's Avatar
whew.....cool...i think mune will be okay then....i guess we will soon find out.
Toadfart
Nov 14, 2005 09:29 PM
HmgLauj69
Mar 21, 2005 11:13 AM
B18EG6
Jun 30, 2004 04:15 PM
slofu
Aug 8, 2003 01:09 PM
Evil EG
Jan 20, 2003 10:39 AM
