gsr tranny in 99 ex coupe. tried 2 diff aftermarket axles both dont fit.
Old Jul 15, 2004 | 03:31 PM
lsvtec101's Avatar
Default gsr tranny in 99 ex coupe. tried 2 diff aftermarket axles both dont fit.
went to autozone got a 99 gsr axle fit in the tranny fine but didnt want to go into the hub, took it back went to foreign autoparts and got one for a 99 SI. fit in the hub but doesnt fit in the tranny. What should i do? this is for the passenger side
rebuild the old one?
Modified by lsvtec101 at 8:10 PM 7/15/2004
Old Jul 15, 2004 | 05:29 PM
murtnabila's Avatar
Default Re: gsr tranny in 99 ex coupe. tried 2 diff aftermarket axles both dont fit. (lsvtec101)
grease up the end goin in. Make sure the ring is centered and try again, should work.
Old Jul 16, 2004 | 05:09 AM
EE_Chris's Avatar
Default Re: gsr tranny in 99 ex coupe. tried 2 diff aftermarket axles both dont fit. (murtnabila)
You ain't the first person I've seen experience this. A friend has a EJ hatch with a B18C swap in it - he ordered up some AutoZone specials and while one of them worked fine, the other just wouldn't go into the hub all the way - I believe the passenger side, if it mattered.
Old Jul 16, 2004 | 05:15 AM
lsvtec101's Avatar
Default Re: gsr tranny in 99 ex coupe. tried 2 diff aftermarket axles both dont fit. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">You ain't the first person I've seen experience this. A friend has a EJ hatch with a B18C swap in it - he ordered up some AutoZone specials and while one of them worked fine, the other just wouldn't go into the hub all the way - I believe the passenger side, if it mattered.</TD></TR></TABLE>
you know what he used for a passenger side axle? im going to get this 95 integra ls axle rebuilt should fit in fine....
leftyvue
22
Jun 30, 2013 10:30 AM
psychobear85
Jun 30, 2009 12:59 PM
creepy116
May 14, 2007 08:07 AM
ThaReal24k
Apr 16, 2005 05:48 AM
lsvtec101
Apr 27, 2004 08:25 AM
