jdm b16b into 99 ex coupe, need help!
I've just recently got done swapping jdm b16b into my 99 ex coupe. My axle boots on the passenger side is leaking grease and i went and got an 99 si axle and it wouldn't fit (btw i got lsd tranny). Anyone know what kind of axle i need?
Re: jdm b16b into 99 ex coupe, need help!
Si axles DO fit, and fix your mount issue before you install a new axle. Or just put a new boot on your current axle.
99-00 Si & 96-00 CTR's have basically the same tranny, other than the LSD.
94-01 GSR axles will fit as well.
But what the other fellow told you, fix your mount first.
CTR & ITR axles do not fit, because they have 36(8?) splines as opposed to 32 splines as the GSR and Si axles have.
I'm jealous of you that you have a B16B because I've been toying with the idea of getting one for my project hatch
Seagull Management
Thats not really true. 98+ JDM ITR axles are 36mm (these are the ones used on the 5 lug setups, the earlier '96 - '97 JDM ITRs used a 4x114 setup and regular 32mm axles) all other B-series civic and integra axles (including CTR and USDM ITR axles) are 32mm.
The things is US auto stores like Autozone don't have CTR axles, pffft... they don't even know WHAT a CTR is. So it's impossible to find OEM CTR parts unless you order it. BUT I'll try the '97 ITR axles.
They don't know it is becuase it was never released here.
Really? I could have sworn it was a option. Matter of fact there is a b16 tranny sitting at a shop by house with lsd, and it is all stock.
EDIT- After some search i guess i was given the wrong infomation. The funniest part is honda told me they did.
Honda told me they had factory lsd, but it was a very rare option and hardly any of them had it equipted from honda.
Bu,t oh well. I guess this is why we dont listen to honda tech's who talk out there ***
im new to this site. i bought a 2000 civic si with a b16b type r swap and i hade to change my axles and now it vibrates on accel? i looked up the 94 gsr axles and they are the same part number can anyone help thanks elia
C3nturion
04-14-2019 07:17 PM
indicajones
06-03-2007 10:37 AM
Dokta
09-14-2004 09:55 AM
lsvtec101
07-16-2004 05:15 AM
