removing "CIVIC EX" sticker
Old Jul 14, 2004 | 04:37 PM
civicboy95's Avatar
Default removing "CIVIC EX" sticker
**I posted this in the apperance section already, but just because i'd like to get input on specificially 5th gen cpe drivers who have actually done this, is why i posted in here also. I understand if it needs to get deleted. thanks
i drive a red 95 ex coupe with that factory "civic ex" sticker on the upper rear pannel (next to the trunk). I would like to remove this sticker, ONLY if it will not leave some werid outline, faded paint, etc. Is this possible, if so, how?
The reason why im so concerend about removing a sticker is that the rest of the car is immaculate and shines great w/ factory paint. Just dont want to put an ugly spot on the car. thanks!
Old Jul 14, 2004 | 04:39 PM
The Mista Mike's Avatar
Default Re: removing "CIVIC EX" sticker (civicboy95)
Think about it, man. It's been on there about 10 years. Unless you have a fresh paint job or your car never sat in the sun, I'm going with faded.
Old Jul 14, 2004 | 05:25 PM
civicboy95's Avatar
Default Re: removing "CIVIC EX" sticker (Mistamike17)
hmm, i was hoping that this would not be the answer. But i guess its just safe not to do anything?
Old Jul 14, 2004 | 05:58 PM
adictionbass's Avatar
leave it on
Old Jul 14, 2004 | 06:01 PM
SupaFly's Avatar
you could remove it.
use wax to get the gooo off of the paint.
If it looks bad go get a new sticker ... Not that expensive.
Old Jul 14, 2004 | 07:20 PM
INDIAN_KID's Avatar
Default Re: removing "CIVIC EX" sticker (SupaFly)
use some floss
Old Jul 14, 2004 | 07:35 PM
Built Beast's Avatar
Default Re: removing "CIVIC EX" sticker (INDIAN_KID)
or a heat gun. If you are removing the badge to hide the fact that it is an EX the sunroof will give it away.
Old Jul 14, 2004 | 07:41 PM
SnowSurfer's Avatar
Default Re: removing "CIVIC EX" sticker (R33CIVIC)
i used a blow driver to get mine off cause i just dont like any stickers on my car i took the stripeing down the side off too...
Old Jul 14, 2004 | 08:05 PM
civicsicko's Avatar
it wont leave any marks, i removed mine, and all there was left was sticky ****, and it was easy to scrub off..
i say DO IT
Old Jul 14, 2004 | 09:16 PM
Deemeetree's Avatar
Electrician
I used WD40 to get the goo off.
Old Jul 14, 2004 | 10:00 PM
DjGuamstyles's Avatar
Default Re: (Dimi)
gasoline worked as well believe it or not. I was about to have a cow when my homie took a rag and put gasoline on it, and started rubbing it on the glue left on after removing the badges, and it came off perfectly fine after letting the gas penetrate the glue along with a little heat friction from rubbing, without harming the paint one bit! Just wash it real good after, but don't use anything abrasive, cause that'll scratch it for sure. But gas is another option...I am sure WD40 will work fine, and is much more safer too, but if you dont got that, use good ol gas, it works great,
Old Jul 14, 2004 | 10:09 PM
t0ekn3e's Avatar
i took my civic off cuz the prevouis owner had it centered but it didnt leave any marks
Old Jul 14, 2004 | 10:11 PM
Street Ghost's Avatar
Default Re: (DjGuamstyles)
I have a red coupe and here's what I did. I warmed it up with a blowdryer and peeled it off. It left a lot of sticky residue, so I grabbed a big eraser and scrubbed away. It took me a long *** time but it came out great. No paint fade, no nothing. I used GooGone before in my engine bay, and as I was wiping away, paint was coming off. So I'd try to eraser method first, if I were you.
Old Jul 14, 2004 | 10:29 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja &raquo;</TD></TR><TR><TD CLASS="quote">No paint fade, no nothing. I used GooGone before in my engine bay, and as I was wiping away, paint was coming off. So I'd try to eraser method first, if I were you.</TD></TR></TABLE>
There is your answer.
Bought time, you're one of 2 individuals that understood this question.
Old Jul 14, 2004 | 10:41 PM
egyolk's Avatar
Default Re: (INVALID)
i was wondering how to debage mine too, anyway you guys should go sign that petition on not having front license plates, even tho our govenator would never pass it..
Old Jul 14, 2004 | 11:25 PM
jerbear!'s Avatar
a razor, some dental floss, and a blow dryer. put those 3 together ;-D
Old Jul 15, 2004 | 12:20 AM
SiKid86's Avatar
Default Re: (jerbear!)
i used goo gone on my cavalier when I had it. I just kept it wet and let the stuff soak in for a few min and the peeled it off.
Old Jul 15, 2004 | 02:10 AM
92b16vx's Avatar
Just peel it off after heating it with a blowdryer, and then use some nail polish remover to get off the sticker left behind. But expect there to be a ghost image or outline to some extent.
Old Jul 15, 2004 | 03:40 AM
upgraded's Avatar
I would think that the fact that the backgound on the decals on the 92-95 civics are clear and if I remember the letters themselves have small lines or spaces running through them that enough light shoud get through to "wear" the paint pretty even so there shouldn't be any fade issues. just yank it off, it was already said, worst case you buy another one, either way it will look better than an old cracked decal.
Old Jul 15, 2004 | 04:29 AM
menkio's Avatar
Default Re: (upgraded)
gasoline.. wd40... you poeple are ******* morons. They make adhesive remover. Goto the "store".. this can be autozone, pepboys, whatever and buy it. 3-4$ a can. Spray, peel off, spray again, wipe the gum mertial off. wash your car... done.
ug.
Old Jul 15, 2004 | 08:05 AM
egyolk's Avatar
Default Re: (DewMota)
yea i was thinking that gas would be a little harsh on your paint? or clear coat... if our eg's still have any clear coat left anyway
Old Jul 15, 2004 | 08:06 AM
egyolk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">gasoline.. wd40... you poeple are ******* morons. They make adhesive remover. Goto the "store".. this can be autozone, pepboys, whatever and buy it. 3-4$ a can. Spray, peel off, spray again, wipe the gum mertial off. wash your car... done.
ug.</TD></TR></TABLE>yea i was thinking that gas would be a little harsh on your paint? or clear coat... if our eg's still have any clear coat left anyway
Old Jul 15, 2004 | 08:21 AM
stickywhiteEH2's Avatar
Default Re: (oversteerINGS)
get 3M glue, wax, adhesive etc., etc. remover..its cheap and its what we use at work (Honda) to take off the adhesive from the plastic on the hood, roof, and trunk of new cars. then use some mothers *paste* wax not a wet wax..that should restore the color of the paint. and if not, like said above, just get a new sticker they arent that expensive..www.inlinefour.com sells them.
Old Jul 15, 2004 | 09:20 AM
jspresso's Avatar
this is what you do, take a heat gun wave it over the sticker to heat the vinyl and then use your finger nail to peal it up be carefull not to burn yourself on the metal and the n take a buffer and some poslish to try to blend it in
Old Jul 15, 2004 | 03:52 PM
Default Re: removing "CIVIC EX" sticker (jspresso)
I'm tellin' you man...don't knock the gas method til you've seen or tried it!!! I'm just telling you from my own experiences with like 4 cars, and WD-40 has to work, cause its got like 101 uses! Of course there's always gonna be a professional product out there to fix these kinds of problems, but its about knowing "what else" you can use that will get the job done.
power11
May 11, 2007 01:51 PM
customcivic74
13
Feb 21, 2005 06:20 PM
akeldama
Jul 13, 2003 07:51 PM
b18c5ivic
12
Dec 6, 2002 05:37 PM
