car won't start
Old Jul 14, 2004 | 02:55 PM
photec2's Avatar
Default car won't start
ok, today i was leaving work and my car wouldn't start. I gave it a min. and it started right up but would idle at 100 rpms, almost staling. i thought it was my IACV so i cleaned it out, and now it doesn't even turn over.
it is...
1. trying to turn over
2. not a fuel problem ( i can smell fuel after i try to start car)
3. can't check my spark plugs because my spark plug socket is to fat to fit in the spark plug holes.
i have a 93 si hatch with stock D16z6 w/178,xxx miles no mods,
my questions is .. would a bad IACV cause my car not to turn over? TIA
Old Jul 14, 2004 | 05:10 PM
photec2's Avatar
Default Re: car won't start (photec2)
anyone??
Old Jul 14, 2004 | 05:38 PM
Blindstuff's Avatar
I have a bad IACV, i idle higher than usual, i dont see that being a problem.
Old Jul 14, 2004 | 06:17 PM
prettyQuik's Avatar
Default Re: car won't start (Blindstuff)
fuel relay did that to me...it will idle really low and almost die. there is a wire to the left of where the fuses are. its kinda thick and covered with some kind of wrap. tug on it a couple times and see if your car starts...i have to do it almost daily
Old Jul 14, 2004 | 07:20 PM
photec2's Avatar
Default Re: car won't start (rexboyb18)
^^ ok i'll try that tomorrow .. its weird tho it worked all day then all of a sudden it took a dump
Old Jul 14, 2004 | 07:44 PM
Andres-eh2's Avatar
any CEL?
Old Jul 14, 2004 | 07:46 PM
Jimmy's Avatar
Global Moderator
https://honda-tech.com/zerothre...75494
Scroll to the middle of the thread and read my write-up.
Old Jul 14, 2004 | 07:57 PM
photec2's Avatar
Default Re: (Jimmy)
thanks a lot i forgot about that ... would that make my horn not work?? cuz it hasn't worked since i have had it.. which is 2 weeks
Old Jul 15, 2004 | 05:42 AM
photec2's Avatar
Default Re: (photec2)
bumpy
Old Jul 17, 2004 | 03:48 PM
photec2's Avatar
turns out it was my dizzy.. i picked up a spare one from a friend (photec3) and swapped the ignition coil and bingo. that was the problem
onemanwolfpack
Jan 4, 2014 06:22 PM
Apple395
Aug 2, 2013 03:11 AM
the.hamburglar
Apr 21, 2007 12:45 PM
GraphiteMW
Feb 1, 2007 06:37 AM
sohcVTEK
Jun 18, 2006 08:44 PM
