OVER HEATING CIVIC PLEASE HELP
Old Jul 13, 2004 | 08:26 PM
prplecivic94's Avatar
Default OVER HEATING CIVIC PLEASE HELP
ok, Im going to resend this again, my car is overheating, I replaced the thermostat, the lower radiator hose, the top is goo still, NO LEAKS, no WHITE SMOKE, new water pump is in. and the fluid level is up to level and has the right mixture of water and antifreeze. they say it could be the head gasket but it only starts over heating when I drive for long periods of time and only when im going up hill....any sugestions???
Old Jul 13, 2004 | 08:30 PM
showtymers619's Avatar
* B A N N E D *
Default Re: OVER HEATING CIVIC PLEASE HELP (prplecivic94)
i suggest bleeding the system.. my way is.. drain all fluids.. pour fluids through top of radiator till fills up.. reconnec to radiator.. keep topping off the radiator do not put the cap on untill the fan goes on
you can also have a messed up radiator ..
Old Jul 13, 2004 | 08:31 PM
JDMlyfestyle's Avatar
when you are over heating. when u feel the upper and lower radiator hoses are they both hot or cold?
Old Jul 13, 2004 | 08:53 PM
well, both are very hot.
Old Jul 13, 2004 | 08:58 PM
The Internet Tough Guy's Avatar
https://honda-tech.com/zerothread?id=629882
on top of that, if you bought a thermostat from autozone or some other cheap parts store, it's very possible that it's defective. i personally have gotten 2, along with dozens of others. take it back, fork over the extra $6 and go get one from honda.
Old Jul 13, 2004 | 09:00 PM
Default Re: OVER HEATING CIVIC PLEASE HELP (jwn7)
so it wouldnt be the headgasket or anything like that or the radiator?
Old Jul 13, 2004 | 09:02 PM
good possibility it could be the radiator.
well I know its not the water pump cause its new, I just had it replaced when I had the timing done...
Old Jul 14, 2004 | 03:50 AM
93CivicSI's Avatar
Could also be the thermoswitch - it tells the cooling fan to turn on -
Could also be a bad thermostat..
Old Jul 14, 2004 | 05:16 AM
mafioso102's Avatar
New User
Default Re: OVER HEATING CIVIC PLEASE HELP (93CivicSI)
Here is what I would do (and btw please only make one thread....multiple threads are annoying)
1. Bleed the cooling system
if still overheating
2. Do a compression check (this will tell you if its the headgasket)
if everything is good...
3. Remove the thermostat (this did the trick for me in my boosted civic)
still overheating...
4. Replace the radiator (while ur at it u can upgrade to a dual core delsol for the same price )
Hope this helps. Also...it might be helpful to know what happens when u overheat (i.e. does it go straigt ot red...does it take a while...etc)
Old Jul 14, 2004 | 05:24 AM
Caretaker's Avatar
bleed the radiator, it's possible that corrosion has fucked up the radiator.
Old Jul 14, 2004 | 02:02 PM
{StatuS ChecK}'s Avatar
Default Re: (lowyellow)
do you have any fuel mods, or other major mods???
You might be running lean. AKA Bad Air/Fuel Ratio. AKA more Fire than Fuel!
Old Jul 14, 2004 | 02:46 PM
gsrcivic1992's Avatar
Default Re: ({StatuS ChecK})
my car was also over heating, come to find out my fan went bad and wasnt kicking on...does it over heat all the time or just at idle?
Old Jul 14, 2004 | 08:14 PM
Default Re: (gsrcivic1992)
well, it only over heats when im going up hills, for long periods of time, and my fan kicks on I made sure of that it does all the time and sitting at Idle it will not over heat...
Old Jul 15, 2004 | 05:26 AM
mafioso102's Avatar
New User
Default Re: (prplecivic94)
have you gotten a compression check yet? Sounds like a head gasket
Christlike
Nov 8, 2023 09:32 AM
TailZ
Honda Civic (2001 - 2005)
Jun 14, 2010 10:52 AM
civicsir94
May 20, 2008 03:21 AM
slikz714
Jul 12, 2006 03:40 AM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
