Will Sea Foam help rings seat?
Old Jul 13, 2004 | 02:11 PM
V8 BAIT's Avatar
Default Will Sea Foam help rings seat?
I just rebuilt and i am afraid that my rings didnt seat due to the amount of smoke coming out the crankcase. I only have 300 miles on the rebuild and i was wondering if anyone has had success using sea foam in a similiar situation?
Also, where can it be purchased?
Old Jul 13, 2004 | 02:46 PM
Kendall's Avatar
I've seen engines smoke for much longer than 300 miles after a rebuild and be fine so don't make any assumptions just yet. I'd be iffy about using sea-foam in a brand new engine, remember it's designed to clean it out. It can be purchased at Napa.
Old Jul 13, 2004 | 04:33 PM
V8 BAIT's Avatar
Default Re: Will Sea Foam help rings seat? (V8 BAIT)
It is pretty heavy smoke and it hasn't improved and i am worried i will get pulled over it is so bad at times... At what point do I realize whether the rings are going to seat or not?
Old Jul 13, 2004 | 04:35 PM
V8 BAIT's Avatar
What in particular got them to seat after more than 300 miles?
Anyone else have take on this?
Old Jul 13, 2004 | 05:15 PM
rapid_roy's Avatar
No, it won't. Wrong tool.
Old Jul 13, 2004 | 05:21 PM
V8 BAIT's Avatar
Default Re: Will Sea Foam help rings seat? (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">No, it won't. Wrong tool.</TD></TR></TABLE>
What is your take, then?
Old Jul 13, 2004 | 07:16 PM
blah13's Avatar
It really depends on your break in method, if you did the slow wasy way then itll take a while. If you did the quick harsh break in the smoke shouldve slowed considerably around 100ish miles. Give it some time. Take it out to a lot and give it some load and decelerating load, try and get those rings pressed into the walls.
Old Jul 14, 2004 | 03:56 AM
Sliced Beard's Avatar
Default Re: Will Sea Foam help rings seat? (blah13)
do a lot of first gear pulls and decelerations to get them to seat well. get as much pressure as you can on teh rings and they will seat soon enough
taggart_lumpy
Aug 15, 2008 01:02 PM
adictionbass
May 4, 2006 07:39 AM
gregv
Mar 3, 2004 05:43 PM
crxfanatic
Jul 26, 2002 03:18 AM
FAST94GSR
Dec 1, 2001 08:18 PM
