help me get running!!
alright, simple setup, d15b7 in a 91 STD hatch.
Its boosted, i just got the car completed, first ive tried to start it.
i have spark, fuel, timing is dead on, and i pulled the upper IC pipe off to get better air to TB.
Car just cranks and cranks, and wants to fire, but doesnt. I pull the plugs and there is no fuel on them..
so, i pulled the fuel rail with injectors in them all hooked up, injectors spraying nicely, all 4 of them, all 4 plugs have spark.
NO CODES at all.
Yet the damn thing will not start.
Any help?
thanks
pat
NO CODES at all.
Any help?
thanks
pat
ive went as far as pulling the harness, not once, but twice, checked every ground, 20 times, literally, im clueless, ive been over every inch of this car from the fuel pump forward, and there is nothing, not one thing out of place.
get a multi meter and out the psotive end on a 12 volt power source, then put the negative lead on the block. what voltage are you getting normally and what voltage are you getting while the car is cranking.
check your distributor you could have a bad coil or some bad internal parts just had same problem with friends b16 swap it crancked but no start had bad coil.
plantmylotus
10
Oct 14, 2008 10:49 AM
