finally running again!!!! have a question reguarding my catch can....
well i am finally up and running again, i got my fully built benson block in about 3 weeks ago and its running mint. No cel's
. its a 83m b18c1 with 9:1 cr.
my question is i am running an endyne catch can setup and upon startup it smoked white smoke out of the breather pretty heavily. it doesnt do it as much now after i let it run for a while, but some still comes out. it maybee has like 15 minutes of run time. is this normal??? thanks
Landon
. its a 83m b18c1 with 9:1 cr.my question is i am running an endyne catch can setup and upon startup it smoked white smoke out of the breather pretty heavily. it doesnt do it as much now after i let it run for a while, but some still comes out. it maybee has like 15 minutes of run time. is this normal??? thanks
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">Make sure you have it mounted up as high as possible and have the drain on the bottom going back to the block.
art</TD></TR></TABLE>
yes i do i have it mounted where the battery is suppost to go.
Landon
Landon
it probly because your rings arent seated yet, they will seat in 20 miles or so as long as your not running super rich and washing the rings out.
Explain what happens if rings dont seat due to washing out and also if it leads to lower #'s on a compression test if this is the case.
i am running a wideband so i know i am not too rich. maybee the rings need to seat, i havent driven it yet just let it idle for about 15 minutes and changed the oil. havent started it again yet, waiting on a few more things.
Landon
Landon
