How do I read/use this?
Old Jul 13, 2004 | 12:55 PM
vwandhondaboy's Avatar
Default How do I read/use this?
Old Jul 13, 2004 | 01:51 PM
alpha's Avatar
Default Re: How do I read/use this? (vwandhondaboy)
https://honda-tech.com/zerothread?id=142398
Old Jul 14, 2004 | 05:09 AM
Default Re: How do I read/use this? (0x64)
Ya, thanx, but I know how to read a compressor map, this is a turbine map, just wanted to know.
Old Jul 14, 2004 | 08:10 AM
TheShodan's Avatar
Moderator
Take the corrected lbs/min of the compressor map for efficiency and compare to the corrected gas turbine flow. match the efficiency b/w the 2
Old Jul 14, 2004 | 08:17 AM
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Take the corrected lbs/min of the compressor map for efficiency and compare to the corrected gas turbine flow. match the efficiency b/w the 2</TD></TR></TABLE>
I kinda get what your saying, but I just want to be sure. So you match it too your pressure ratio from the compressor map, then you take your flow (lbs/min)
from the compressor chart at 68%?
BlueShadow
Nov 25, 2005 08:57 PM
*Boostwerks*
Sep 27, 2005 03:44 PM
*Boostwerks*
Sep 22, 2005 09:25 AM
SleepinTeg
Jun 18, 2005 08:54 AM
D-Man
Sep 12, 2004 01:41 PM
