clocking turbo question
do i have to have the turbo out of the car to clock it? ive read all the clocking post, but my turbo is on the manifold with all the lines connected... can it still be done? or do i have to take everything off? the reason i want to clock it is because my revhard manifold puts the compressor outlet right on the bottom edge of the stock radiator. im looking into buying a thicker racing radiator, but they are THICKER. Car is an eg with a b16. thanks for any help if you can.
hmm ok, i was just wondering mostly because after i loosen the 6 on the compressor side, it should be pretty hard to turn it??? ive never clocked one b4, so im not sure.
Do you have to loosen the bolts on the compressor housing as well as the turbine housing to clock the middle part of the turbo?
Mine is already installed in the car as well... Any pics would be greatly appreciated as the other pics on H-T are down.
Tofurky
Dec 7, 2002 04:48 PM
