Do i Have everything???
Old Jul 12, 2004 | 12:53 PM
StolenTeg's Avatar
Default Do i Have everything???
So, Im going the hondata way to tuned my car. Never heard anything bad about it and i hope i will make some decent power. Since my car is a 98 LS OBD2a, I brought a OBD1 p75 ecu, OBD2a --> OBD1 conversion harness. and Hondata s200B is on the way, hoping kteller will be able to shipped it next day air or something for me. I decided that i will be going to DRT in Woodside NY for tuning. Heard some good thing about them. so those are all the thing that i would be needing right? i dont want to arrived at the shop and then find out i miss something.
Old Jul 12, 2004 | 06:06 PM
StolenTeg's Avatar
Default Re: Do i Have everything??? (StolenTeg)
What kind of power should i be looking at 7psi??? im hoping something over 200whp? Will it be a problem if my downpipe is leaking exhaust gas. the greddy downpipe is gay, i need to find someone who make an aftermarket one asap.
Old Jul 12, 2004 | 07:41 PM
NVturbo's Avatar
O.G. triple O.G.
AC Delco 3bar MAP sensor, upgraded injectors, and of course, a lil' racing gas wouldn't hurt (100+ octane grade)
Old Jul 12, 2004 | 08:22 PM
StolenTeg's Avatar
Default Re: Do i Have everything??? (NVturbo)
No no, im not planning on doing any of those stuff. I just wanted to go and dyno tuned to get my a/f timing correctly so i wont blow up. my stock map sensor should hold up to 11psi and im only tuning 7psi so it good for now. the 310cc should hold up since i dont think ill be making a lot of power. Im just worried i might missed out something on converting to obd1 to go hondata...
Old Jul 12, 2004 | 11:43 PM
Mr.DC2TurBo's Avatar
Make sure your p75 ecu is hondata rdy and I believe hondata requires at least 440cc injectors.
Old Jul 13, 2004 | 08:40 AM
StolenTeg's Avatar
Default Re: Do i Have everything??? (Mr.DC2TurBo)
What do you mean by my ECU is hondata ready???
Old Jul 13, 2004 | 08:42 AM
pin28 needs to be solder. You can send your ecu to hondata for 65 dollars and they can do it for you.
Old Jul 13, 2004 | 09:23 AM
StolenTeg's Avatar
Im going to a hondata dealer, would they be able to do it???
Old Jul 13, 2004 | 10:06 AM
not sure. I know for sure if u ship it to hondata the company in CA then they will do it. check out their site at http://www.hondata.com for more info.
Daltonamo
Sep 17, 2010 09:43 AM
93delslow315
May 27, 2010 09:23 PM
FuNkDrSpOt
Aug 25, 2006 03:24 PM
Schister66
Nov 10, 2005 08:28 AM
